Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor Duel-Fuel ERD30 oven does not work
First the IR gas broiler stopped responding, the controls indicate its on, but nothing happens. A week later the control panel and clock go off as if there is no power (I have checked the house electrical panel), yet the light works and the self cleaning button makes a sound then a few seconds later another one as if shutting off, either way it does not work. Any idea what the problem is? I have had 2 other service calls for our down draft and stove top igniters. TIA for any suggestions.
  • 1894 Answers
SOURCE: Dacor Oven Death
i think ur breaker is dead
Posted on May 15, 2008
Krazytech
  • 725 Answers
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
dovaleh
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Posted on Jan 10, 2009
SOURCE: code fpf flashes on clock on ge elec stove model jbp26gs1ad
I am sorry, but there is no such error code mentioned among the GE Fault codes.Or this could possibly be because of a faulty display.The display can be replaced on a call.
Else the possible error code similar to this one is "PF" which refers to power failure but generally not related to kitchen range.
Please do check if there is a display change of the error code and post your valuable comments. would be glad to help.Good luck.
Posted on Jan 16, 2009
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
My Dacor RSD305 duel fuel oven does not work.
you need service
when set the display starts off at min temp
if no heat rise is present it will shut off
check your house breakers first
Jun 06, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERSD36S09 Dual Fuel Dacor; broiler doesn't work
I had a similar problem. My broiler wouldn't light but the igniter was glowing. It turns out this igniter has to glow virtually white hot. If it's red or orange it probably needs replacing. I bought a new one from Appliance Parts Pro's. However, when I look at pictures of these things they all look exactly the same. My guess is all appliance manufacturers use the same unit.
To change it on the Dacor you need to pull off the back panel. Loosen the unit inside by removing the screws and shake the wires so someone else can see which ones. Disconnect the wires from the connectors and tape a piece of thickish string to it. This allows you to pull it out from inside the oven and have a way to get it back in past all the little turns and corners. My replacement had bare ends so I cut off the old connectors and soldered them to the new unit. However, I would guess you could use wire nuts instead.
Nov 18, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Infrared broiler won't heat
My broiler igniter has gone out once in my 8 yo ERD30. The tech was nice enough to tell me how to replace it myself when it went out again, and so it has. So now I'm looking for the part online! Check out the thread here: http://applianceguru.com/forum1/12935.html
Sep 10, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
76 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
