Question about Samsung HT-HDP40 System
Samsung HT-HDP40 Equipment needed
I got a great deal at Cons on a Samsung HT-HDP40 system but it was soled as is, which means there are none of the factory speacker wire, video, audio connection or owners manual with the system. I see the some of you have had problem with this system and I would like to learn from your experinces and get a copy of the owner manual from one of you if possible. I need this so that I can order the wire and connector that are needed to operate the system. Thank You in advance.
  • feeskeg Jan 05, 2008
    i need the connectors as well have you had any luck
    i need the 3 speaker wire connectors that plug in the back of the
    dvd player. does anyone know where i could buy the custom connector or
    something that could be used in place of it. samsung wants 60 bucks
    President:
  • 3,130 Answers
Http://www.samsung.com/download/agreement.htm is where you want to go to get everything you need for your unit! Click on agree and enter your model number, as this is not a US model and this model has to come from the global download center. Good Luck
Posted on Aug 23, 2006
SOURCE:
HT-C555/XEU manual
Do you mean the Samsung HT-C555 digital home cinema system? Samsung has the manual for this on the product support page: http://www.samsung.com/uk/support/model/HT-C555/XTR . Scroll down (or click the Manual Download link) then expand the section with the See More link. The direct link to the more recent version of the manual is currently: http://downloadcenter.samsung.com/content/UM/201011/20101119141546000/HT-C550-ELS_ENG-1025.pdf . The XEU appears to be about the remote and different retail areas had slightly different remote model numbers. The manual for the HT-C555 covers several models and gives information on the remote control on page 13-14.
I hope this helps.
Oct 20, 2017 | Office Equipment & Supplies
I am looking for the clips that goes onto the raw speaker wire ends that clips into the back of the receiver
Normally the speakers and receiver just have a hole that lines up when you push on the head, and a spring pushing back makes contact on the bare wire, when you let go. But if your receiver has jacks or screw terminals instead, then you will have to get them at Radio Shack. They just crimp onto the wire with a pliers or special crimping tool.
Feb 06, 2010 | Samsung HT-HDP40 System
Ht-hdp40
speaker cables are located behind the speakers inside the box...so u would have to take out the speakers to get to the wires
Nov 02, 2009 | Audio Players & Recorders
DVDs freeze every few seconds while playing
this could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
Jul 07, 2009 | Samsung HT-HDP40 System
Samsung HT-XQ100
Does it happen with all discs? Maybe clean the discs because I notice the player is pretty sensitive
Jan 14, 2008 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Speaker wire connector
Yes you can try Bogue Engineering at www.BogueEngineering.com they carry awesome connectors and for your system you need the 4,2mm size. They only cost $21 for a set of 6 and they are much better than Samsungs parts. Hope that helps.
Gary
Jan 05, 2008 | Samsung HT-HDP40 System
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Samsung HT-HDP40 System Logo
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
