Question about Garmin Nuvi 660 GPS Receiver
Gps garmin nuvi 660
Hi my gps garmin nuvi 660, suddenly says not acquring satellite. It has been over 2 weeks. I have tried putting it outside a while, but it keeps up with the same thing. help me
  • Garmin Master
  • 2,130 Answers
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Posted on Oct 27, 2008
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Jan 01, 2017 | Garmin GPS
Trouble acquiring satellite
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
May 23, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 660 CHRONICALLY looses and has lost satellite signal Any thoughts? (and yes, in clear sight of the sky)
if it is in your car, i am thinking you may have one of them funny windscreens and may need an outside aerial?
Jan 01, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 cannot acquire satellites
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
Jul 19, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
660, hangs up totally after ca. 40mins use
Hi Martin,
It sounds like a corrupted firmware update. Please go to this site:
http://gpsinformation.org/perry/nuvi/
I believe the latest firmware version for a 660 is v4.7. You can try reflashing the firmware with v4.7 or trying an earlier version. Let me know if this resolves your issue.
Also, the Nuvi can lag if you have large picture files on an inserted SD card.
- Jim
SHARCNET-USA
Feb 13, 2009 | Garmin Nuvi 660 GPS Receiver
Ribbon cable for nuvi 660
u can get it at radioshack websites
or u can try this link above
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
Nov 16, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Can't find Satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Jul 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 680 -cannot acquire satellites
Im not 100% but im thinking that if the ribbon connecting the reciever to the unit can become dislogged or damaged, im trying to find a replacement ribbon.
Jun 24, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
273 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
