Question about Whirlpool WFW9400S
Re: won't spin
My Whirlpool Duet will fill with water but will not spin. I also put in a small load and it still won't spin. We've had it for a year this month.
  • 903 Answers
Try checking the outflow pipe is clear of blockages. Look under the sink where the outflow pipe attaches to the ubend and with a pot handy to catch any water remove the pipe and check to see if any hair/fluff etc is blocking it, then check the ubend. If this is clear then the carbon brushes in the motor may need changing. If it is still under guarantee and it is not caused by a blockage then connect the company you bought it from and they should send out an engineer.
Posted on Oct 26, 2008
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet won t spin continues to beep and
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: my whirlpool duet washer is filling about 1/4 with...
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%$$
Posted on Sep 30, 2010
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Washer fills up 1/4 of the tub on its own.
Sounds like a defective fill valve leaking water in although the machine is off.
First turn off your water and remove the hoses. Clean the screens in the hoses and the fill valve.
If that does not correct the problem replace the fill valve.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer throwing H the F code
f06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Sep 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load Washer
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9400S Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
