Question about Kitchen Ranges
Can't get the oven door to unlock
Was sitting in front of my electric range and reached across it and one hand touched on the touch pads on the front causing the oven door to lock. Now I can't get it to unlock. manual says to touch and hold down the stop/clear button for 3 seconds until it beeps. This should unlock it-well,it didn;t. Please help!
    Scholar:
  • 155 Answers
Please check out this link http://www.applianceaid.com/nuker.html
good luck. thanks.
Posted on Oct 26, 2008
After cleaning the oven the fan runs and we get an F1 code, the door will not unlock.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 08, 2010 | Jenn-Air JMW8330DA Electric Double Oven
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Ran the self cleaning cycle on my Kithen Aid electric range and once the cycle finished the touch pad would not unlock, the oven door unlocked but none of the touch pad will work except for the the button...
This is a common problem with all self cleanig ranges. The 1200+ degree heat will sometimes leak up into the control panel and damage components. Try turning the power off first for 30 minutes and see if the control resets itself. If it doesn't have directions on the panel, then check you owners manual to see if their is a certain procedure you use to unlock your contols. If none of these work you will need to have a technician come out to diagnose your elecronic range contol or you touch pad. Good Luck Appliance Specialists
Dec 14, 2009 | Food Processors
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
When operating the oven I will get a beeping with the error code F-5, F-1, and F-3 should I replace this range
or
Oct 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
