Question about Dehumidifiers
Challenge ram 710 manual
Need instructions and stopper
Dehumidifier manual
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Aug 17, 2014 | Dehumidifiers
Where can I get a stopper to stop the water coming from the continious exit pipe and divert it into the water tank on my Amcor SD10 dehumidifier
Sorry it's taken so long for someone to respond to your question. The reason may be, that it's not very clear to us, what exactly you're trying to do. I think it's the part about "the water coming from the continuous exit pipe" and why you would want to run it into the dehumidifier tank?
So, if you could explain the specifics a little better, we may can help you.
Thanks
Apr 05, 2011 | Amcor Dehumidifiers
How to defrost a dehumidifier lost instruction
Simply turn it off and let it set! this will allow the coils to thaw.
Nov 27, 2010 | Dayton Dehumidifiers
I replaced the control board FD2518-020, which included the temperature sensor that mounts to the side of the condenser. The condenser now freezes over and the unit continues to run. I experimented and...
Was there any instructions with the control board? I'm assuming we are talking about a heat pump control board or defrost board.
Some have time or temperature settings on the board that needs set. There's a lot of different boards out there, some have jumper pins and some have dip switches, you almost need either the unit installation instructions or the instructions that should have came with the board. Not sure if this will help you but if it doesn't you may need to contact a dealer or the company that made this unit.
Aug 05, 2009 | Maytag M7DH65B2A Dehumidifier
The water does not go into the tank in the unit, but leaks on to the ground.
Make sure the disc- like stopper plug for garden hose connection point on the rear of the unit is tight. Also with the pan removed make sure that the drain hole to the pan is not obstructed...good luck
Jul 15, 2009 | Haier HDN655E Dehumidifier
Amana D565M
yes - take the hose off and put the plug back in. You may need to refashion a plug if you don't have it. One of those old chemistry class stoppers for a test tube would be perfect.
Aug 14, 2008 | Dehumidifiers
Need to replace the overflow stopper gadget.
CONTACT YOUR LOCAL MAYTAG REPAIRMAN. THEY WILL PROBABLY NOT ONLY SELL YOU THE PART BUT WILL TELL YOU HOW TO INSTALL IT. THEY WILL ALSO BE GLAD TO REPAIR IT FOR YOU AT A NOMINAL FEE. GOOD LUCK.....JLR4
May 31, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
366 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
