Question about Pioneer DEH-3400 CD Player
I dont know where to put ground wire for pioneer 3400ub
There is a ground wire coming from the inside of the car which is a circle and a ground wire that came with the wire kit or whatever its called, i own a 95' dodge avenger and have no idea what to do to the ground wire people have told me to put it on metal on the car but where does the other one go or where would both of them go actually? i can email back and forth and will send pictures if needed? please get back to me, angelo15@live.com
  • Angelo Brigolin Feb 19, 2012
    so the ground wire itself coming from the car i connect to the metal of the car? and then the one from my wire kit to the frame? still not 100% sure I understand fully
  • 21 Answers
Its too simple, the main body of it is actually ground itself,,try to tie a wire or screw on body of it,, wish u luck
Posted on Feb 19, 2012
Deh-3400ub set clock
Follow the instructions on page 4 of the manual.
Mar 15, 2012 | Pioneer DEH-3400 CD Player
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt...
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Sep 08, 2011 | Pioneer DEH-3400 CD Player
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Dont know the wiring diagram
Positvie is red, ground is black, and or black with a white stripe. the yellow wire is also a positive wire, it is the memory wire which should be hooked to something that will always be hot, even when the key is completely off. If you have a power antenna, that is controlled by the blue wire
May 03, 2009 | Pioneer DEH-1000 CD Changer
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer DEH 3700 ground problems/system noise
Very common with pioneers. their is a ground loop fuse-located inside the head unit, that has to be repaired at the factory. Or, the best way-just like you said, is to ground the rca's, solder a thin wire to each rca, easiest and cheapest way. I had it happen to me with a 4800.
Mar 23, 2008 | Pioneer DEH-3700MP CD Player
Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Sep 01, 2007 | Pioneer DEH-P690UB CD Player
Pioneer DEH-3400 CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
