You will need to sign into your eBay account and edit your profile.
Keep in mind that you will also have to change your address (or add the second address) in PayPal.
If you already have a purchase made, you need to contact the seller directly to make sure that they send it to your address.
Vous devrez vous connecter a votre compte eBay et modifier votre profil. N'oubliez pas que vous devrez egalement changer votre adresse (ou ajouter la deuxieme adresse) dans PayPal. Si vous avez deja effectue un achat, vous devez contacter directement le vendeur pour vous assurer qu'il l'envoie a votre adresse.
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
you must go into your account details of the place you are placing your orders and find your account details then change the billing adress form usually is the same as postal adress then they will send an email to your email adress to confirm that you have changed it
hope this helps
Can you ping the ip address? By default, the ip address should be 192.168.0.1. You can verify by going to Start, Run, cmd. At the command prompt type ipconfig /all and you will see the ip address, dhcp server, gateway, etc. The gateway will be the address for the router. Type ping 192.168.0.1 (if that is the address). Also, the default username is admin and the password is left blank.
Not sure what it is you need from us???
