Question about Panasonic KX-TG6702 Phone
Panasonic kx tga560az base frozen
The base has frozen. it works but none of the buttons work. it is not the handset..any ideas on how to reset it?
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
  • 15 Answers
SOURCE: kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Posted on Nov 23, 2008
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
Panasonic handset, KX-TG5632 buttons won't work
After trying all possible solutions (unplugging, replugging unit; switching batteries and, my idea of smacking the handset with my hand), I bought a new phone. :-)
Feb 07, 2009 | Panasonic KX-TG5632 Phone
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
Uniden Power Max 2- Missing one handset which is off-hook
Unplug the electrical power to the base unit and plug it back in again. This will reset it.
Feb 13, 2008 | Uniden Cordless Phone
Panasonic KX-TG6702 Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
