Question about Compaq Evo D510 PC Desktop
Compaq Evo Problem!!
When I Try to turn on my compaq evo , it makes 1 long beep and 2 short beeps ,and the Num lock led from the keyboard keep flashing. and the monitor don't start...
    New Friend:
  • 84 Answers
Hi
this probleme causing by graphic card put the new one and try
Posted on Feb 19, 2012
5 Suggested Answers
Geodavis
  • 45 Answers
SOURCE: compaq evo d51s beeps on boot
Try replacing the RAM (Random Access Memory) Stick
Thanks
Posted on Oct 25, 2009
  • 28 Answers
SOURCE: Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Posted on Nov 19, 2009
  • 53 Answers
SOURCE: my compaq evo d510 cmt keyboard lights flashing constantly
first problem its a compaq go buy something else no seriously buy something else
check your bios settings F10 for compaq if i remember corectly might be F2
http://h18000.www1.hp.com/products/quickspecs/11349_na/11349_na.HTML
http://reviews.cnet.com/desktops/hp-compaq-evo-d510/1707-3118_7-20719364.html
i mean com on 533 bus and dosnt saport multi core cpu's
my 2004 dell 200 mhz buss saports quad core wth
if its not a bios setting replace your keyboard good luck
Posted on Feb 25, 2010
Geekman
  • 32281 Answers
SOURCE: my compaq evo beeps 1 short 2 long but nothing on
This POST (power on self test) error code could be this depending upon the BIOS manufacturer.
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Posted on Feb 27, 2010
I bought a 2nd hand compaq evo D500 desktop whose power supply was dead.I kept it unused for 1.5 years.Now I have bought another power supply which is working fine BUT nothing is diplaying on the...
Check that you hooked up all the power supply connections. Try a new motherboard battery as the old one may be dead and the bios is not working. You are evidently not getting a post beep signaling that the cpu, ram, video are good.
Nov 27, 2013 | Compaq Evo D500 PC Desktop
My Compaq evo d510 c system turns on it gives one short and two long beeps with no video. please help. thanks
What i did,
I replaced VGA card with the new(taken from the other dead pc) one and also l found one RAM was dead, so i had to remove it and the PC was working fine..!
According to the technical reference manual for the evo D310, 3 beeps is a memory problem.
Check page 52 of this document.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00658282/c00658282.pdf
Aug 14, 2011 | Compaq Evo D510 Minitower (Open Box)...
I have a Compaq Evo and everytime I turn it on it switches between *turning off within three seconds* or giving me 3 beeps and then just staying on without any visual signal. I cant even get into the...
Three beeps at POST (startup) may be caused by an issue with your video card. Check to make sure the video card is seated correctly. If you have another video card, you can try it to determine if the current video card is faulty.
Mar 02, 2011 | Compaq EVO D5S SFF Refurbished Desktop...
Salut J'ai un Compaq Evo, à
can you post a question
on English?
you can see, just English here so...
good luck
or go to real HP and ask.,
https://h30434.www3.hp.com/
Jun 07, 2017 | Compaq (283983-001) Motherboard
My compaq evo beeps 1 short 2 long but nothing on screen
Feb 27, 2010 | Compaq Computers & Internet
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Compaq evo d51s beeps on boot
Try to reseat the memory sticks. Sometimes they just need reseated.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Compaq evo will not boot up
try to go to BIOS
if the pc is not allowing you to go BIOS then get a bootable cd & insert the same & boot the pc to the desktop & also open the chasis & reseat the memory sticks.
Apr 10, 2009 | Compaq Evo D310v PC Desktop
Installed new DIMM memory in Compaq D510 CMT - puff of smoke
Here's a full list of the POST beeps for your computer:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00704816/c00704816.pdf
That flashing numlock and beep pattern says there is no system memory. When you let the smoke out before it might have been fatal for something. It could be the memory itself is dead, or something could have been damaged on the system board that is keeping it from detecting memory. The only way to know for sure is to try another stick of known good memory.
There's also the possibility you used the wrong kind of memory when you added the new part. Here's a link to the hardware guide for the computer:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00706221/c00706221.pdf
You can use the information to be sure any memory you get is supported.
Hope this helps you. Good luck getting the computer running.
Jul 31, 2008 | Compaq Evo D510 Minitower (Open Box)...
Compaq Evo D510 PC Desktop Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
