Orient Automatic Sapphire day - Computers & Internet
  • David Howard
    David Howard Feb 19, 2012
    I'm having problems changing the day on my Orient Sapphire Automatic EV0J-C0-B, can anyone help me with this
Why are there two wires to the horn on a ford sapphire
it grounds when you hit button same with older dome lights
Mar 18, 2015 | Ford Cars & Trucks
How do i cancel my account with sapphiremembers.com
Cancellations - You have a 21 day cooling off period from the date of this letter where you may cancel your membership
and receive a full refund without any recourse or further charges. However, no cancellations will be accepted if the
Sapphire Dining card has been activated/sent out by request. If your cooling off period has expired, you enter into the
initial 12 month Sapphire membership program. Cancelling your membership to Sapphire once the membership is fully
active (after cooling off period) will ensure you are not billed for any further annual terms, but as your current annual
membership has been paid you may continue to use the service for the remainder of your term. You may not obtain a
refund for membership fees paid after the initial cooling off period. To cancel this contract simply email us on
cancel@sapphiremembers.com including your customer number, name as it appears on the front of this document,
telephone number and full address registered on your Sapphire account. Alternatively you can call us on 08435070707
or fill in and return the cancellation form below by post.
Feb 06, 2015 | Computers & Internet
DRIVER FOR Sapphire Tech SAPPHIRE 100172-64L
Try this website, please:
http://www.drivermanager.com/en/drivers.php?Brand=Sapphire&Logo=sapphire&gclid=CISa6MqQ_LQCFQSg4Aod5icA1Q
Jan 22, 2013 | Sapphire Tech SAPPHIRE 100172-64L SAPPHIRE...
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
Jun 03, 2011 | Orient CEUAA002WW Wrist Watch
I have an "Orient Fineness Ultramatic" men's automatic wristwatch, 35 jewels, approximately 1967 vintage, one-piece case. It runs, but needs cleaning and lubrication. Is there a reliable watchmaker who...
mcdevito75 here, Hello John, Orient Ultramatic, 67" beautifull watch and Vintage, Our Repair Service Directory should have a watch repair person who can service your vintage watch. At the bottom of this page Click on Repair Service Directory then watches. Please be aware, like any machine John, your vintage watch has wear in it, the gears in the gear train, have the slightest play between the teeth, the main spring and hairspring are not as tight (rigid, springy) as they were when your watch was say, 3-5-10 years old, these factors all contibute to your watches off time as a matter of speaking. You may want to consider a complete over-haul of your Orient Ultramatic watch. I am Mike D of the RITE TIME BASICS, listed in the Repair Service Directory here at fixya. (email mcdevito@netzero.com)Or you can choose any of the other fine watch makers here at fixya"s Repair Service Directory.
Aug 19, 2010 | Orient Watches
How do i adjust date and time
the knob at the side....
  • First pull which will change the date.
  • Second pull which will set the time.
thank you
Apr 06, 2009 | Orient Automatic Sapphire World Timer...
Detecting fake orient watches
I also like to buy watches from time to time.
The fakes being made today are done very well. Naturally, they do not come near to the quality of an original one. Many of them are now made to weigh the same and feel like the real one!
The best way is to open the watch and look at the movement. If you know watch movements you should spot right away if the watch is okay or not. If there is a serial number mark it down and call or email the manufacture of the watch.
If you are buying an expensive watch and you do not know them seller very well, and you cannot inspect the watch in person, you are taking a chance!
I know of a few instances where people bought watches where they thought they were getting an excellent deal. They ended up getting a clone watch.
Take care when buying used name brand watches, collector items, antiques, or high end film cameras.
Jerry G.
Sep 15, 2008 | Orient Automatic Divers Cem65006d Watch...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
