Question about Sony PlayStation 3 (250 GB) Black Console
My ps3 is stuck on 99% in a system update, if I re-start it just automatically goes straight into the system update and again gets stuck on 99%. How can I fix this?
  • Liesel Moreno Feb 20, 2012
    I've left it overnight and it stil stays in 99%
    Top Expert:
  • Sony Master
  • 79,189 Answers
Leave it alone, this update can take up to one hour to complete
Posted on Feb 19, 2012
4 Suggested Answers
  • 100 Answers
SOURCE: i attempted to update the
If the power button hold doesn't work...try this...,
Take the clip out that holds the drive. Take the screw out but leave the drive inside.
When the update begins, pull your drive out. You will get an error message and it tells you to restart your system to try again. Instead, let the time run out, and your screen will go blank for about 30 seconds until it starts back up telling you that you need to reformat the drive. (If you don't get this message after 30 secs the first time, YOU HAVE TO REPEAT IT till it does. Then put your drive back in again making sure your controller is plugged in (wired in with USB) and press the PS3 button on the controller. It will then ask you to either press start and select at same time OR PS3 Button PRESS START and SELECT. Do not agree to any user agreements!! Make sure you hit cancel and it will reset to the startup screen.
* Just wondering....did you recently open your ps3?
Posted on Dec 14, 2010
DarkNeogen
  • 109 Answers
SOURCE: ps3 not working
Is there sound? If so, then maybe your video settings got mixed up. Try the video reset.
When the PS3 is in standby mode (red LED lit), hold the Power "button" until it beeps for booting, keep holding until it beeps again (not to turn it off).
If done correctly you should see something again (480p resolution) allowing you to change settings.
I hope this will help you out.
Greetings,
DarkNeogen.
Posted on Jan 29, 2008
  • 41 Answers
SOURCE: My ps3 is stuck on the system update screen on
Your PS3 hard drive may be corrupted. Do you know, send back to game shop is too expensive and waste your time. Learn the repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only hard drive problem, you can repair other red and yellow light issues as well. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Posted on Jul 20, 2010
Trying to run a system update on PS3.
Remember to start system up in safe mode. There are several videos on youtube that show you how.
Jun 12, 2014 | Sony PlayStation (PS) Console
I attempted to update the system from a game and now it's stuck. when i turn it off its just starts the update again and every time it gets stuck on 99% and it just stops. i tried getting to the restore...
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
On a system update it only goes to 99% and stops and doesnt do anything else
First go into your system settings and find 'Media Connection' in network settings. Disable that and try again.
If that does not work, download the update from your pc to a flash drive or disk and update your PS3 that way. http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Lastly, if the above does not work you may need to disable UPnP in your router settings if you are using a router to connect your PS3.
If you do not know your routers IP adress do the following:
-Go to the computer connected to your router, click start and select run in the bottom right.
-In the run prompt type cmd and click ok.
-A black window will pop up. Type ipconfig and press enter.
-The 'Default Gateway' will more than likely be your router's IP address.
-Type that number into your internet browser.
-That will connect you to your router and the menu setups will vary based on the type/brand of router you have.
-Find a setting called 'UPnP', disable it, and try your update again.
Dec 10, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is working perfectly with firmware 3.40 .I started to update firmware 3.41 on thursday 5/8/10 Then i had a problem with my ps3. At first the ps3 downloaded data successfully then it started to...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur PS3 ....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is stuck on the system update screen on 99%. When I turn it on, it automatically goes to the system update screen. It sits at 99% for about a half hour before it gives me error code 8002f318. I've...
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Code 80010006
software problem i thing not you
May 02, 2010 | Sony Playstation 3 (PS3) Console
Game wont load on ps3
i had this same problem and the solution to mine was that my ps3 was in my garage and it was too cold in there for the system to operate so i moved it into the living room where it was warm and it eventually began to work
another solution is to just restore the system and then reinstall all of the updates
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
System update will not finish
On mine it gets to 64% and then says there is an error (8002F1F9) and when i turn it off & on again it goes straight back to the update and keeps failing at 64%.
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation 3 (250 GB) Black Console Logo
974 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
