Question about InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector
Laptop screen resolution
When i connect my laptop dell inspirion m5030 to my infocus projector, the projector changes the display resolution, and I cannot see full desktop on screen. How can I prevent this automatic change.
  • Lawanda Hill Feb 19, 2012
    Thanks for answering, but it doesn't solve my problem. After I connect, my screen resolution automatically changes to lowest resolution, and that is when I cannot see the entire desktop. The option to change resolution is then greyed out so I cannot change it back.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
When u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Posted on Feb 19, 2012
My projector wont display what is on the computer.
Every laptop has a facility to toggle the display from the screen to an external display. The exact method varies from brand to brand. But they're all a variation on the same theme. It's the Function button (Fn) and one of the F keys. On my HP its Fn + F4. I've had laptops in the past where it has been F5 and others that were F8. All of them though had a little symbol representing a screen on the correct key.
The way it works is that the laptop screen is on. The first press of the two buttons will put both screens on. The next press is just the output to the projector. The final press brings it round to the laptop only again.
Once you have just the projector running, then you should change the display resolution to suit the projector if the laptop hasn't already done it for you. You can tell when it's wrong because the text won't be crisp. Right click on the PC desktop and then select "graphics properties" or similar from the menu. Change the resolution from the drop down box. Click OK to confirm. The correct resolution for a projector is the native rate. This is the number of pixels on the display, not the maximum resolution.
Sep 08, 2014 | InFocus Office Equipment & Supplies
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
How to change screen resolution on dell inspirion 1010 to 1024 x 600
To change your screen resolution1.Open Display in Control Panel.2.On the Settings tab, under Screen resolution, drag the slider, and then click Apply.3.When prompted to apply the settings, click OK. Your screen will turn black for a moment.4.Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Jan 29, 2012 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
My dell vostro 1088 can not display a picture to infocus
The hot key for Dell to show your display in the projector is fn f8. Alternatively you can configure your display by right clicking on the desktop and choosing graphic option or graphic properties to configure the display to show both on your laptop and the projector. If you have done this and still it will not display in the projector, try lowering the resolution and/or frequency of your display. Use the lowest first and the make it higher to check up to what resolution it will work.
Feb 28, 2011 | Computers & Internet
Dell 10" mini netbook is unable to display the entire contents of a web page. The bottom part is cut off. I tried changing the resolution to 1024X768 but it keeps popping back to the default.
Simply change the screen resolution.
Steps
Right Click on your Desktop
Click Properties
Then go to the Display settings
Select a lower resolution
Your problem will be solved
Cheers
Sep 01, 2010 | Dell Inspirion Mini 10 Netbook
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
May 19, 2009 | Dell 2007FPW UltraSharp 2007FP 20.1-inch...
Infocus projector 4805 connected to Toshiba laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
2.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector Logo
254 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
