Kenmore He3 Door Switch Problem
We have a 9 yo Kenmore He3 front load washer that has been skipping the final high speed spin cycle. After researchinging online I learned that it is most likely caused by the door switch. Upon inspecting the entire door operation I observed that the door sags causing the latch to not align with the switch strike. We held to door tight shut when the high speed spin should happen, and it did high spin. Can the door be realigned, or do I need to buy a new hinge assembly? Should I assume that the door switch has been spoiled and replace that at the same time? Thank you.
  • Washing Mach... Master
  • 5,763 Answers
I would say the door should be removed and take a good look at how it strikes switch, it may just be a switch adjustment or door adjustment, with the front door panel remove you can adjust and test to see if switch is closed with a meter, this may save you money, heres a video on the link, its all about your washer, it shows you how to take it apart hope this helps,
if the door is too bad to adjust then replace it ,but i think with a little adjusting it will be okay, note make sure door rubber seal is in place also.
Posted on Feb 19, 2012
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Kenmore front load washer goes through wash and rince cycles but will not spin
These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Replacing the Door Lock and Switch Assembly on Kenmore Front-Load Washing Machines
Mar 05, 2011 | Kenmore Washing Machines
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Loud racket when spinning at high rate f speed
yes it is going. if you go here
www.techray1.com and select the guru guy he will take you another window where you can select the part needed. also the repair manual is availble for your unit.
Jun 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
