Question about Bosch Washing Machines
I have a Bosch Maxx Classic that leaks water that seems to be coming from the Solanoid/ Can anyone help with a fix.
    Genius:
  • 1,212 Answers
Inspect back side of solenoid for cracked hose or cracked plastic body. If those look okay, unscrew the hose connection and replace the flat seal. It is the same size as a garden hose fitting, and will accept one of those as a replacement until you can find one that is approved for washing machine use, or jsut replace the hose, which should be done every few years as a precaution against a burst hose.
Posted on Feb 19, 2012
ginko
  • 19396 Answers
SOURCE: I can't seem to get any power to my Bosch Maxx
If you are in UK, check the fuse inside the power cord.
If the power cord is not fused, then you need to replace the control board, or fix a wiring problem, since this machine does not have any fuse in control board.
If you need to call a technician you can use the phone number listed on the owner manual.
Posted on Feb 24, 2009
  • 1525 Answers
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Posted on Jul 21, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
beltronic205
  • 1467 Answers
SOURCE: How do I fit a new door latch to a Bosch Classic Maxx 1200
try utube video
Posted on Oct 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Maxx Classic wont drain
The correct procedure for removing the filter is to unscrew it anti clockwise, and pull it out.
If it does not come out, then it is possible that there is something stuck in the filter, or the filter seal has swollen
As you unscrew it, try moving it from side to side at the same as you are pulling on it, then screw it back in again, and try the same procedure.
Hope this helps.
Posted on Dec 21, 2009
Bosch classic washing machine has a f17 error code anyone know the fix for this?
web pages suggest that it is a water supply problem---no water coming in
check tap turned on and passing water( faulty tap washer )
check for power to water control solenoid ( solenoid failure)
check for power to solenoid ( program board problem)
call a technician for a proper diagnosis
Jan 09, 2017 | Bosch Washing Machines
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch maxx 900 manual
It could be caused by a damaged heater element.. remove and check for damage. One way to check is to remove the two wires and tape up to prevent accidental short circuit. set machine to a cold wash if it does not trip you know what you have to replace. if it still trips then remove the motor and check carbons/ brushes for excessive wear. good luck..
May 10, 2014 | Washing Machines
Bosch maxx 1000
The fill valve may be clogged or defective
Oct 14, 2017 | Bosch Washing Machines
Bosch maxx 7 varioperfect
On the bottom front there is a panel, that panel is the 'sump' area. Make sure that is cleaned out so that all water can eject during rinse cycle.
Nov 19, 2013 | Washing Machines
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch maxx wfl 1300 washing machine that wont start.
shaun
Jul 21, 2009 | Bosch Washing Machines
I can't seem to get any power to my Bosch Maxx Classic washing machine yet it was working fine when I initially turned it on. I have tried using other points to no avail. Can anyone help?
Feb 24, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
248 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
