Question about Hotpoint Aquarius WMA56 Front Load Washer
Drum Does not Rotate
4 years old drum just suddenly stopped rotating. Fills ok empties ok via ! selector but after filling nothing, Checked belt was ok checked for loose connections. Losts of carbon dust around belt.
  • 1 more comment
  • Kyka Oct 27, 2008
    Took motor out checked brushes. They were contacting armature so took them out cleaned them and refitted. Hey presto working again.;-) although motor refit was a bit fiddly and the belt was just a **^%$£** to fit. Thanks very much. Gonna buy a new set of brushes and fit when I can.
  • Anonymous Mar 24, 2014
    It fills and empties fine it just won't agitate
  • Anonymous Mar 25, 2014
    drum will not rotate freely when turned by hand
  • 566 Answers
The carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Posted on Oct 27, 2008
  • silver top Oct 27, 2008
    well done! thank you for your update and pleased to hear you were successful and are now more knowledged as to diy your machine ? for info the brushes cost approx £ 5 uk andwhen fitted in carriers will be level with the top of carrier whilst brushes are out try cleaning armature up and you could use one if wifes fine nail file then vac out ? i hold nail file against and rotate the belt pulley by hand alway works i would consider renew of belt? hope it lasts another 4 yrs? best wishes
Wfl 2260 5 years old The drum does not turn the
if you can here the motor running have you checked the drive belt is still fitted to the drum,,,they fall off at times or wors still they brake,,,
Jul 04, 2010 | Bosch WFL 2063 Front Load Washer
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
My WFL2080 fills & drains but the bowl doesn't rotate
Sounds like belt has fallen off if easy to turn .Failing this check motor brush kit...
Apr 21, 2010 | Washing Machines
My mini washer samsung does not tumble
pl. remove rear cover and see if belt is broken ? if belt is ok also check freeness of drum by rotating with hand.
Nov 07, 2009 | Samsung WF337AA Front Load Washer
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Sep 23, 2008 | Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Sep 21, 2006 | Ariston Technologies AWD121WH
Hotpoint Aquarius WMA56 Front Load Washer Logo
187 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
