Question about Toshiba Satellite L515-S4010 Notebook
Display area blured
A strip in the middle of the display has white and light blue lines, whcih makes it difficult to see through
    Problem Solver:
  • 19 Answers
It is having a video failure. or screen going bad and unfortunately its part of the motherboard. Hook external monitor to it if good picture then screen bad. If monitor has bad picture then video on motherboard bad and very exspensive
Posted on Feb 19, 2012
Laptop dell latitude d830 started by demanding a start up repair which didnt work then started showing white strips which turned dark and darker then black. After another switch off and on it turned to...
The problem is most likely one of the following, all of which will require that the laptop be taken in for repair:
1: Cable from motherboard to display has become damaged or partially disconnected.
2: On board video circuit is failing.
3: LCD display is failing
4: Inverter for LCD display is failing
Sep 19, 2017 | Computers & Internet
My asus laptop display is showing a blue or purple haze bar through the middle.
sounds like you are right there do it before the warranty runs out!
Dec 09, 2012 | ASUS G73JHA1 Notebook
I HAVE A KENWOOD DNX9980HD 20 PIN HARNESS THAT CONNECTS TO THE KENWOOD HEAD UNIT. I ALSO HAVE AN AXXESS ASWC (STEERING WHEEL CONTROL MODULE)20 PIN HARNESS THAT CONNECTS TO THE AXXESS ASWC. THE AXXESS...
HI,
If you make a close verification on the back side of kenwood DNX9980HD 20 PIN HARNESS then you can see a Light Blue wire with Yellow stip ( BLUE/YELLOW) on it with a identification mark as "Remote cont". You have connect this wire to the Brown wire with white strip (BROWN/WHITE) from the 20 PIN HARNESS of AXXESS ASWC . There wil be a brown wire also from this 20 PIN HARNESS of AXXESS ASWC, leave it free insulated. It will not use with kenwood radios. You have to check for LIGHT BLUE with WHITE strip. There is also two other blue wires of which one with white strip. You hve to choose the light blue wire.
ok
Aug 06, 2011 | Car Audio & Video
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
03 monte carlo ss power seat wont go down. how to fix?
i have a 2003 monte carlo and the wires came out of the plug under the seat. im trying to put them back in so my seat will be able to work. there are 12 wires that make up 6 connections. i need to know what wires go together. the wires are red with blue strip, red with green strip, red with white strip, yellow with blue strip, yellow with green strip, yellow with white strip, light green, green, peach, blue, light blue, and yellow.
Jun 08, 2010 | 2003 Chevrolet Monte Carlo
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Have a GE arctica SxS model PSC23SGRCSS with dispenser not working. have just now replaced motherboard and dispenser control panel with no result. any ideas what else to do?
we checked the wire connections that run through the freezer door, along with the water line, under the fridge. we found that the white wire was badly corroded and not making contact with other connections in the terminal. we clipped the 3 pin wire harnesses from each end, and stripped the ends of the wires. we reconnected blue-blue, white-red, and black-black, using sodder. we then insulated each connection with electrical tape, and used electrical tape to shield the unit from the water line. it worked! i don't think that either the motherboard or display control panel were defective to begin with, but we just left the new ones in place.
Jun 20, 2009 | Refrigerators
Don't know how to add anything
there are 2 ways to put content on your ipod.
one is making playlists and syncing your ipod..you go to file on the top and create playlist.
add songs to the playlist and sync the play list.
another way is to open you itunes with the ipod connected and on the left side you will see 3 sections in the light blue shaded area. the middle section represents you ipod and it's contants, click on music and the music folder will open in a large white window to the right of the blue shaded area.
maximize your music folder on your computer so it is in front of itunes.
drag and drop songs into the first column of the large white area.
drag the song and hold it over the white area, when the border of the white area turns blue drop the song and it wil load onto your ipod. you can do multiple songs by hgilighting the first song pressing the shift key on your keyboard and highlight the last song in the set. left click and hold, drag and drop in the first column of the white area. make sure to watch for thr border to turn blue then drop the songs.
May 30, 2009 | Apple iPod MA446LL/A MP3 Player
The BLUE crosshair will not focus,
go here
this is for sony but your should be close enough. you want to manually focus the blue gun.
please mark post fixya!
Feb 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba Satellite L515-S4010 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
