I have a viewsonic N3760w tv and it takes a long time to turn on. I will press the power button on the tv and remote, and it takes 2-5 minutes to turn on. What is the problem. Please help.
    Genius:
  • 1,212 Answers
It may be a bad solder joint on the power supply board, it may also be a failing capacitor on the power supply board, It would require the board to be removed from the set and inspected visually as well as with a capacitance meter. Inspecting the solder connections for a questionalble one takes some time, but it may also be faster to simply reflow the solder connections on all the solder joints on the board.
Posted on Feb 19, 2012
SOURCE: viewsonic N3251 doesn't turn on right away
Solution... Call viewsonic and **** till you get a new one (diff model). Good luck, you're going to be on hold forever.
Posted on Feb 10, 2008
SOURCE: Viewsonic N3760W
Following up on my earlier post, I replaced all but the (physically) largest electrolytic capacitors on the power supply board, 16 in all, several that exhibited the "domed" top of an expired part. Ta-da! It's been running for several hours and looks great. I have an electronics background, so I was comfortable with sourcing and replacing the components. If you are not familiar with electronics component values and practices, DO NOT ATTEMPT THIS YOURSELF!. The correct parts are critical for safety and performance.
Posted on Jan 14, 2009
  • 121 Answers
SOURCE: Viewsonic N3760W won't power on
Try unplugging the set from the AC power source wait for several seconds and then plug it back in. Cross your fingures and hope that the reset works!
Posted on Feb 25, 2009
  • 139 Answers
SOURCE: How do I change the power supply for my Viewsonic N3760W TV?
YOU HAVE A VOLTAGE/CURRENT LIMITER PROBLEM THAT IS PROBABLY CAUSED BY A LEAKY CAPACITOR IN THE FEEDBACK CIRCUIT IN THE POWER SUPPLY. THIS CAN BE FIXED. I CAN GUIDE YOU IF YOU CAN SOLDER AND FIND THE PARTS- RADIO SHACK OR MABYE AN OLD TV AROUND?
Posted on Dec 27, 2009
Testimonial: "Awesome help."
HnstTrstMe
  • 12 Answers
Very carefully. I only would do it after you have verified the warranty is expired per Viewsonic. If it is OOW, then you can call them for a service manual that contains schematics, troubleshooting flowcharts, etc.
Posted on Aug 20, 2010
My viewsonic n2751w tv will not stop channeling down... have to put weight on top to stop
mmm sounds like a sticky channel switch on your tv itself. Spray some special stuff called Contact cleaner spray available at any electrical outlet or hobbyshop - its a little bit expensive but works great to clean motherboards and most other electrical equipment. Spray while the tv is off and press buttons in between sprays
Jan 14, 2015 | ViewSonic N2751W 27 in. LCD Television
I wont turn on viewsonic n3760w.
Viewsonic N3760w LCDTV no power. IrishDruid is quite correct in suggesting that you keep it on at all times. If you switch it off you have to go through the hair dryer routine again (12 minutes the second time around). If it does not appear to work when nice and hot switch it off at the mains and it will come on. Presumably that somehow resets it. Thanks again ID.
Aug 02, 2011 | ViewSonic NextVision N3760W 37 in. LCD...
N3760w displays 'locked out' when I hit menu buttons(no r/c )
A possible solution: http://www.techsupportforum.com/home-support/electronics/433897-viewsonic-vt2430-lcd-tv-button-lock.html
Mar 13, 2010 | Televison & Video
How do I change the power supply for my Viewsonic 37'' Model # N3760W LCD TV. It keeps turning off when I change channels and adjust the volume. I cant order one from Viewsonic.
Dec 27, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
TV (#N3760W) won't turn on (immediately).
sounds like the board connecting to the power switch going bad. are you using remote?
Oct 17, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
I cant convert my 24" ViewSonic remote to my Comcast remote
Try and re-do your codes for your remote. If you don't have the codes try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | ViewSonic NextVision N3260W 32 in....
Feb 25, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
LCD TV N4060w can not power on
I had the same problem...first it would take two or more power button presses to get the tv to turn on. Finally it would not turn on. It was the power supply and was easy to replace.
Dec 16, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
3735w Viewsonic Power lock problem
I had the same issue on my Viewsonic N3752w
The online guide, said I had to press VOL+ and Menu at the same time, but forgot to say
a) it's from the TV buttons NOT the remote!!!
b) you need to keep pressing these 2 until it stop saying "Power unlocking" but Unlocked.
Sep 14, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
