Question about Sony PlayStation Portable (PSP) Console
Remove psp front cover
Can u find me some instructions that i can print on how to take off the front psp cover
    Problem Solver:
  • 4 Answers
I dont know of any instructions to print out to tell you but i can tell it to you plainlly
if you have the 2000 version of the psp system there are 7 screw u need to remove
1 on the bottom
4 behind the battery
and 2 on the back right side you will see the holes for them there
after you get those screws out u carfully pull the front and back apart the front part is your cover it
be careful cause the buttons fall out
Posted on Oct 27, 2008
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Replacing the back of a psp
Please consult those instructions in the following URL.
If you find this solution useful please rate it as solved.
Thank you
http://www.psp411.com/show/guide/53/0/Changing_PSP_face_plate.html
Oct 20, 2007 | Video Game Consoles & Games
No screen is coming on psp
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 15, 2010 | Sony Video Game Consoles & Games
MY PSP WONT ON EVEN YOU WILL CHANGE ITS BATTERY
Apr 12, 2010 | Sony PlayStation Portable (PSP) Console
Nothing on the screen when psp is switched on
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  1. Confirm that the printer is powered on.
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do i change print cartridge?
Plug in your printer, turn it on, then lift cover from front, not just scanner cover, reach lower. Carriage will move back and forth a few times before settling in middle of printer. Pull forward on both levers to release covers over print cartridges. Lift up on cartridge on end closest to you and then pull toward you and up to remove cartridges.Remove tape from new cartridges and install as per instructions on box new cartridges came in or just reverse removal instructions.
Feb 04, 2010 | Lexmark X3650 Printer
PSP HOME KEY KEEPS COMING ON
The game case is not needed to run the game. Usually when you have the problems like you are experiencing you simply need to clean the disk in the case. You can sort of pry it apart to clean any finger prints off of the game disk. A single finger print is all it takes to prevent the game from running.
If you are unable to get the game cover apart try to use Windex on a soft cloth to remove the prints.
Dec 10, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
