Question about Dryers
Proline tdc7a makeing an awful noise when being used
Makeing an awful noise
4 Suggested Answers
SOURCE: Proline TDC7A Dryer (condenser)
Have you checked the connections from the pump unit to the water receiver? There are several connections at the rear of the unit which take the water from the condenser, to the pump and then to the reservoir, could be a leak? Run the machine where you can see the rear and monitor it, something may become apparent. Hope this helps. Richard
Posted on Jan 27, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Posted on Nov 26, 2008
hunter19_46m
  • 7482 Answers
SOURCE: My heater isnt working on my Proline TDC7A tumble
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Posted on Oct 15, 2009
Proline manuals
did u check the door switch?>
Jul 11, 2014 | Dryers
The automatic door lock makes awful noise
a new door latch/actuator is required
May 31, 2010 | 1999 Jeep Grand Cherokee
Electric oven makes an awful vibrating noise when hot
yes it can,i have used double sided sticky tape tp put between the blower houseing and top
May 26, 2010 | Ovens
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
My heater isnt working on my Proline TDC7A tumble dryer I know there are 2 thermal cutout switches which may either need resetting or renewing but where do i find them ?
Good Luck,
Hope this helps
Oct 13, 2009 | Dryers
No heat from my tumble dryer
Nov 26, 2008 | Dryers
Jan 02, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
