Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing F My duet is flashing "F" - what does this mean and how can I fix it?
  • chester4444 Oct 27, 2008
    i have the same issue but mine flashes f20
  • Ron Coons
    Ron Coons May 11, 2010
    usually itr flashes a number after flashing F, that number is the key to the fault that your experiencing
The error came in as F- then 01 flashing I don't see 01 on troubleshooting page. My son forgot to add his sweater to the wash so he stopped it only after five min and opened the door to add it then the error came on. How to fix this?
Thanks,
liz
Posted on Oct 30, 2008
    Scholar:
  • 155 Answers
Check out this link for the error codes u receive and how to resole it manually
http://www.applianceaid.com/duet_washer.html#duet
good luck thanks.
Posted on Oct 27, 2008
What does it mean when a duet front loader washing machine flashes F02?
f02 mean that the drain time is to long check the drain pump filter that is behind the lower front panel
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo Duet Dryer is flashing an error code of E1. What does this mean and what is the fix?
E1 Thermistor open Replace thermistor if found defective
replace the thermistor on backside of unit behind back panel... i think its part number 8577274 you can find this on repairclinic.com, or searspartsdirect.com, or you can shop locally, let me know how itt goes
Mar 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet ht and at a certain place in the cycle I get an H & F signal flashing....what does that mean? And how do I fix?
You can find fault codes here.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Not sure which problem your having but this might get you started.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does "F 20" mean when it is flashing
This Error Means that Water is Not Detected by the Machine. There could be many Reasons for the same . Read the Below Article that works for most of the people :-
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Unless :-
1. Check Hoses. It should not be clogged or kinked or blocked.
2. Make sure Inlet Valves is Turned ON and Working.
3. Pressure Switch and Hose are in Good Condition and there is no Water Leak.
There could be several other reasons which needs a Professional on Site.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It need fixing go and check again..
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing Light
check ot this above link to know what this error code means and how to resolve it.
good luck.
thanks.
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What does this cod mean?
Post you email i will email you the PDF of the service manual but the only code i see is a F which equals FAULT the the "code" is H which is a no water detected entering the machine or Pressure switch trip not detected
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
