Question about Siemens Lands Phones
My SIEMENS optiset E Memcy S30817-S7008-B101-9 has a ringer problem
I can make a call but there is no ringtone to incoming calls
  • 201 Answers
SOURCE: simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Posted on Nov 12, 2007
  • 149 Answers
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
  • 63 Answers
SOURCE: Turn the ringer on for external calls.
in system programming
Posted on Mar 14, 2009
consultel1
  • 860 Answers
SOURCE: phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Mar 26, 2009
  • 211 Answers
SOURCE: The phone does not ring - ringer is off.
Look for the "Sounds" icon on the home screen. It looks like a speaker. The icon you describe seeing during an incoming call is actually a button on the touchscreen. Even though the phone is on vibrate, touching that should silence the phone for that call. Also, once you click on the "Sounds" icon, you can scroll down to "Set Ring Tones/Alerts", which will allow you to customize specific sounds for every event within a given profile.
Posted on May 28, 2009
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
No ringtone on Katana phone
Sure the phone is not in sient mode.Is loud speaker working. if not change N2150 ringer IC or get it changed with a technician.
Nov 19, 2008 | Nokia 1110i Cellular Phone
I don't seem able to find the list of ringtones on the phone. It only has one at the moment which is pretty annoying!!
It seems that most Samsung uses the same pathway to get to ringers and assign them to incoming voice calls. Here's the pathway in your phone (hopefully)
menu > settings > sounds > ringer types > voice calls > select with caller id or without caller id (your preference) > single tones/ringtones, melodies or my content and press menu/ok
Aug 19, 2008 | Samsung Cell Phones
No ringing tone or incoming call sounds.
The primary phone sets the ring for all phones. If it is off, nothing will ring. Once it is on you may set the volume of the rings on all sets individually. If you have the manual, look under Ringer Off on the main set. Hope this helps, let me know
Feb 18, 2008 | Siemens optiset E Corded Phone
Motorola V235 mobile phone
the ringer speaker might be damaged or is in mis contact... jksut go to nearest technician and get replaced with new ringer....
Dec 07, 2007 | Motorola Mobility V235 Cellular Phone
Incomming rington volume
try putting on vibrate and ringer for incoming calls. i had that problem and it fixed it
Sep 27, 2007 | Samsung SCH-u740 Cellular Phone
No sound for incoming calls on SK65
Is the ringer off? Can reset but you will loose stored info.
Aug 19, 2007 | Siemens SK65
Incoming calls
Try to reset the unit with the phone again.
Feb 25, 2007 | Motorola Mobility H500 Wireless Headset
Lands Phones Logo
90 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
