Question about Bosch Washing Machines
Eltek 10026941 I have a Bosch MaXX Advantage washing machine which today will not fill with water. I have removed the supply hose and no water will flow through it even though the mains water supply is good. The hose is fitted with something labelled Eltek Type 100269 41 max 90 degrees. I do not know what this thing is and whether or not water should flow through it when disconnected from the washing machine. Any help would be appreciated. Can I replace this with a normal supply hose? Thanks Ken
ginko
  • 19396 Answers
SOURCE: Bosch Maxx Washing Machine My fabric
Check the hose at the back of the softener drawer, check that they are not obstructed, check also that the lever closing and opening the holes for softener and detergent is moving regularly
Posted on Apr 27, 2008
philbran
  • 242 Answers
SOURCE: bosch continues to fill when rinsing even when the machine is off
The inlet valve is stuck open most commonly , you can check this by taking the wires off the valve and then turn everything back on , if the water is still flowing replace the inlet valve.
Phil
Posted on Apr 14, 2009
beltronic205
  • 1466 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
rickead1
  • 1998 Answers
SOURCE: we have a bosch maxx it will fill up with water
motor or drive problem this can be a couple different situations depending on if your unit is belt driven which would be a easy fix you have to be able rto take off the upper cover to inspect the motor drive area
Posted on Apr 28, 2010
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Showing error E5
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Jul 29, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
My bosch maxx 1000 washing machine
A very common cause is that the electric solenoid operated water inlet valve has failed. It is inside the console at the top where the hose screws on.
Jul 22, 2014 | Washing Machines
I have a Bosch classixx 1200s Expresss. When I press the start nothing happens and a get a 12 beep alarm (4 then 4 then 4) every 60 seconds. There is power and water
I'm not an expert. I just had the same error (on a Bosch Maxx 6) and fixed it by chance.
My area has a lot of debris in the water supply, and it turns out that the small filter in the hose connected to the water supply was completely clogged up. You can either replace this filter, or clean it as outlined below.
Here are the steps to cleaning it:
1) Unplug washer
2) Turn of the water supply, either by a turning the handle to the washing machine water supply or by turning of the water main.
3) unscrew both ends of the water supply hose
4) Screw the washing machine end of the water hose into the water supply outlet
5) On the other end of the hose, there is a small filter. Hold this in place with the tip of your finger, and turn on the water supply for a few seconds, while keeping the free end of the hose in a bucket. This will flush water through the filter in reverse, thereby cleaning it. Do NOT reverse water flow with one end still attached to the washer machine, as this will flush all the debris into your machine!
6) Turn of the water supply, unscrew the water hose, and reconnect both ends as specified by the manufacturer.
Hope that helps!
-Dennis
Apr 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
We have a bosch maxx it will fill up with water
Apr 28, 2010 | Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Washing Machines Logo
691 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
