Question about Hotpoint Ultima WF865 Front Load Washer
WF865 HOTPOINT ULTIMA - front loader
During fast wash (60deg), about 10minutes into it, the machine beeped and the word H2O flashes on the screen. What does this mean and what do I need to do please?
Connect a hot water supply
Posted on Nov 01, 2008
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Oct 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Fault
h20 means it's not getting any water or not filling fast enough. check your water pressure.
May 02, 2008 | Hotpoint Ultima WF865 Front Load Washer
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf865 problem
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Mar 22, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Feb 08, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
249 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
