Question about Garden
I have a Bosch aquatak 120i the motor keeps running all the time
    Sergeant:
  • 316 Answers
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Posted on Feb 19, 2012
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Jun 18, 2015 | Bosch AQUATAK GO Pressure Washer
Roto power lance 'jet' keeps sticking
internal ceramic swivel is obstructed or broken, insert fine wire (supplied) into head then back flush head, or replace head, checkout ebay
Mar 17, 2014 | Bosch AQUATAK 115 PLUS Pressure Washer
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Bosch aquatak 120i pressure washer/tetergent
Hi hope i can help!!
Try this empty the detergent tank then have your machine ready to work then half fill the tank with warm water and use the machine, this may take a few attempts so dont think its a 5 min fix! What happends is the detergent when left in the machine goes thick and gooy the warm water thins this and eventualy cleans it out but dont use boiling hot water this may damage the seals.before storing machine away do this method.
Hope this helps .Sean
Mar 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
542 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
