Win 7 will not shut down,the message ,shutting down,will stay on the screen for hours
  • Christopher Gage Feb 19, 2012
    It has happened all all the time .It is 3months old and has windows Starter,my desktop is win 7 ultimate and does the same thing
    Problem Solver:
  • 19 Answers
If this shutdown problem started recently I would go back into windows and click start then programs then accessories then system tools and restore to the last date you were shutting down correct
Posted on Feb 19, 2012
  • 624 Answers
SOURCE: Computer will not shut down
You can try the Ctl-Alt Del keys to see if you can get the task manager to come up. If you can then try to shut down using that. If not then the only choice you really have is to manually power down and restart. Chances are pretty good Windows will clean up after itself and should boot backup. During the process if you receive any error messages or warnings document them. Windows may also prompt you for a hard drive scan, let it. Let us know what happens and please don?t forget to rate this post.
Posted on Apr 16, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Posted on Jul 22, 2008
  • 68 Answers
SOURCE: shutdown
Hmm, could be an overheating problem.
Do you have any temperature monitoring software on your laptop you could use to check the cpu temperature while watching streaming video?
If not try downloading and installing this.
http://www.almico.com/sfdownload.php
Regards
Nick
Posted on Oct 26, 2008
ArnWuLF
  • 55 Answers
SOURCE: Dell Inspiron 1520 won't shut down when printer connected.
Try disabling the startup items or edit it. Go to Start -> Run. type msconfig. Choose Diagnostic Startup. Reboot.
Please rate this if this is helpful.
Posted on Dec 09, 2008
  • 53 Answers
SOURCE: HP Pavilion dv6000...startup and shut down...over and over !
if the other ideas dont work then its a bad motherboard this is common in compaq and hp laptops the chip sets overheats and goes bad HP knows here is issues with the boards but has done nothing to fix this as yet.I belive the is a class action law suit dealing with HP laptops with these issues
I run a computer shop here and deal with replacing mother board in laptops more then any other repair. you can pick up a board on ebay.I buy lots of laptop board on there just make sure you you get a seller with good feedback.i have yet to see a laptop the cycles on,off,on to be any other problem.
Posted on Feb 20, 2009
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
T43 screen dims and laptop will not shut down
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
Nov 05, 2012 | IBM ThinkPad T30 2366 Notebook
My toshiba L745-s4235 laptop is shutting down randomly
Sounds like a failing hard drive or it has some bad sectors.
Oct 19, 2012 | Toshiba 14.0" L745-s4235 Satellite Led...
Norton utilities 15 has stopped working
try this
norton will not install if there is a previous installation still installed so you have to uninstall completely all norton installations
Then try installing the program
Win 7 may be the problem so make sure that the norton15 is compatible with win 7
Feb 14, 2018 | Norton Antivirus Computers & Internet
WINDOWS NOT SHUTTING DOWN COMPLETELY
dude i think its the BIOS prob try reseting the bios u can do so by removing the maotherboard battary for one min aand then replacing it this will surely rester the bios.this should it
Feb 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
Hp dv9000 will not shut down or burna disc correctly
What error message is being 'thrown'?
If your system boots and runs take a look at the "Event Logs" on your system. They can reveal a lot of information.
Have you added any new software to your system? Have you had any "Automatic Updates"downloaded and installed? WIN XP SP3 has been known to cause a few problems. Try un-installing WIN XP SP3 and see if this helps.
Do you have a virus program and an anti-spyware program? If you do update them and run them. Let me know what happens. Binary Bob
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
