Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Model MAH5500BWQ
Washed a "Cush Pillow" the pillow came apart and tiny styrophome beeds are stuck in the washer, how do I fix this?
  • Maytag Master
  • 5,568 Answers
I would fill the tub again, let it agitate a little and then start scooping the floaties up with a kitchen sieve.  Don't let it pump water until you think you have most of the styrofoam beads out of it again. Unless they are a different product than I'm familiar with, they shouldn't really damage the pump even if they are cheap plastic pieces of junk.
Posted on Oct 26, 2008
    President:
  • Maytag Master
  • 2,651 Answers
UUGGGGGGGHHHHHHH, nothin to do but tlet them run there coarse, hope the y dont clog the pump , in which case oyull need to disassemble pump assy and clean from there as well. nothing you can do now except get put what you can and continue using
The care instructions have faded off the tag on my isotonic indulgence pillow. I need to wash pillow. can you instruct. thanks
My pillow has its tag, which does not contain washing instructions. The description on Amazon says the removable pillow cover is washable. I take that to mean the pillow itself should not be washed.
Mar 12, 2014 | Isotonic Indulgence 100% Cotton Pillow
Washed a pillow and it exploded. Cleaned it out filled again did not wash does not make a sound does not spin does not empty NOTHING
If it is a front end washer some of the pillow maybe stuck behind the rubber between the door and the washer tub. Pull back the rubber and see if anything is stuck behind it. All the fibers from the pillow may have jammed the tub and made the machine overheat. Clean out anything you can reach and see if that frees up the tub. If the tub is moving look in your owner's manual and see if their is a reset button. Also check and see if the electrical fuse is kicked off, especially since most washing machine are on GFI outlets which are easily set off.
Oct 07, 2013 | Washing Machines
Door wont lock will not close properly
Cut and paste this factory service manual.
It will show how to access,test and replace all components.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Jul 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hello. I think this is the model..it looks
Well Bridie no there is no lint filter inside your washer the only possible explanation, is either old lint and particles are coming from previous washes. or you have just washed something recently that may have come apart such as a pillow, a mat with a rubber backing, or even a blanket with any sort of fiber material in it. It is more than likely that much of the lint that goes through your machine is unseen and can cause pump issues. hope this helps.
Thanks
Oct 12, 2009 | Maytag PAV2300 Top Load Washer
Wash time too long
if the water supply is restricted, yes this would happen. remove supply hoses, check screens, check taps
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Waont drain
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Dec 21, 2008 | GE Washing Machines
Washer is not draining
yea popping off the front cover to access the pump assy release the hoses leading to the pump and remove the debris clogging the pump assy
Mar 17, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
