Question about Citizen CLP-7201E Thermal Label Printer
How to fix head error of clp-7201e - Citizen CLP-7201E Thermal Label Printer
  • gardo Feb 19, 2012
    how can i fix this problem . . . i don't know if the machine or software came this kind of error . . help me. .
    thanks in advance. . .
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
May 10, 2010 | Samsung CLP 315 Laser Printer
How do i fix Fuser error 3 on clp-650
order a new fuser .... fusers wear out over time
Sep 03, 2009 | Samsung CLP-600N Laser Printer
Samsung clp-300 Error message is "fuser low heat error"
your printer toner is not installed properly. pls shake the toner & fix again.
Sep 01, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
Error Jam0 in tray1
GO ON LINE TYPE IN MANUFACTURE NAME,MODEL#, ERROR MESSAGE AND ENTER KEY LIKE THIS:
CAMSUNG CLP-500 LAZER PRINTER ERROR MESSAGE JAM0
ENTER
ROD
Feb 09, 2009 | Samsung CLP-500 Laser Printer
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Cut err
Paper Cutter Error - Guiliteen isnt sliding across the  rail it runs on properly  try lubing rail that cutter runs on with a LITTLE light oil , near front paper exit area
Oct 19, 2007 | Citizen CLP-7201E Thermal Label Printer
Citizen CLP-7201E Thermal Label Printer Logo
147 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
