I have been saving files on a zip drive disk for several days now. It's worked flawlessly. Now, today, I try to access the disk, and it's unreadable. The files I have on the disk represent several hours of work, so I'm about to have a nervous breakdown! Help!!!
    Master:
  • 538 Answers
Yeppers..zip drives will make you crazy...un hook from computer..get new drivers, install, put a new zip drive in naked
and give it a whirl..
Posted on Oct 26, 2008
How Can i Fix Zip Drive Not Working in HP LaserJet Printer?
The problem may not be with the Zip drive. Load the disk in the zip drive and open the file . Once you can open the file on your computer it should print the same as any other file. I do know there are lots of problems with not being able to read files saved on Zip disks.
Oct 05, 2017 | HP Office Equipment & Supplies
Trying to uninstall nero 7 essentials in my laptop, shellmaneger is missing
http://www.nero.com/eng/support-nero7-tools-utilities.html download the tool and follow these directions
  1. Download the file "infotool.zip", save this file to your desktop.
  2. Extract the zipped file on your hard drive using WinZip or WinRAR.
  3. Double-click on the EXE file to start the Nero InfoTool.
  4. The window "Nero InfoTool - Retrieving Information" will open. Please wait until the progress bar has moved completely to the right. The window "Nero InfoTool" will open.
  5. Click the "Save" button (the disk icon at the top). The window "Nero InfoTool - Save/Print" will open.
  6. Please activate all the check boxes (Drive, Disk, Configuration, Software, Hardware, etc.).
  7. Click the "Save" button. The window "Save as" will open.
  8. Name the file and select the "TXT" format as the file type in the dropdown menu.
  9. Select in the "Save in"-dropdown menu the "Desktop" entry.
  10. Click the "Save" button. The Nero InfoTool will be saved on the desktop in the "TXT" format.
  11. Close the two windows "Nero InfoTool - Save/Print" and "Nero InfoTool".
  12. Please send us this file as an e-mail attachment if you contact technical support.
Mar 10, 2011 | Computers & Internet
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
I have a Western Digital external hard drive (MyPassport Elite) and it has stopped recognising it. I recently got a new laptop with Windows 7 after my last one with vista broke. It worked fine for the...
Make sure you're using the cable supplied. I have a Passport Drive that came with a 6" cable which I found to be too short. When I used a longer cable (and of an unknown quality) I started having intermittent read / write faults. I had the drive replaced by the store the next day. I started having the exact same issue with the new drive as well. I was told by the store manager when I tried to return the second drive that I should use the supplied cable, and when I did - it worked flawlessly.
Make sure your power supply (if yours included one) is connected too. Hopefully, the will solve your problem - good luck!
Nov 08, 2010 | Western Digital Computers & Internet
How to save data from hard drive off my apple power book g4
You can drag and drop your files on to an external hard drive or USB flash drive, burn the files to CD/DVD using an application called toast - you will need a CD/DVD writer to do that. If you can find one, you can save your files to a zip disk.
Dec 04, 2009 | Apple PowerBook G4 Mac Notebook
Reinsalled windows xp lost all my drivers i have a nother computer with vista how can i use my zip drive tocpy to my xp dell
Hello, first thing you should do is (assuming you have USB zip drive) plugin you zip drive in make sure it works.
from the other computer that is working with internet access, Visit http://support.dell.com/support/index.aspx?c=us&l=en&s=dhs
select drivers, and then specify your model of dell computer and download NIC (ethernet card/network card) drivers save them to the ZIP disk and carry that over to XP PC and copy drivers from zip disk to the desktop. double click and run the file you downloaded and note down where it is extracted,
in dell its usually "C:\dell\Drivers\Rxxxxxx" folder.
next right click on my computer, go to properties->hardware-> then device manager, locate the network card with Yellow exclmation mark. Once located, right click it and select "update drivers" from next screen select the option "No, not this time" then on next screen check "install from a list or specific location (advanced)" option and click next.
then simply browse to the location where you saved the drivers (by default C:\dell\Drivers\Rxxxxxx, note xxxx are numbers related to the drivers) and select that folder and click next. That shold take care of it...
let me know if you have any other questions.
regards
Amar Sondhi
Dec 03, 2009 | Dell Ethernet Card Network Adapter
Unable to see data on Zip Disks
You are saying that you used zip drive in 1998. i want to tell you that in 1998 the processors were of old versions.therefore,you need to install windows 95,only then you will be able to retrieve your data.
As the only reason to be found is that you used win 95 in 1998,now you are using win xp,the files you stored on your drive were only supported by win 95,hence you need to install win 95.
THANK YOU. hope you get a well experience on www.fixya.com
Oct 10, 2009 | Iomega Zip 100MB (31714) External ZIP...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
MS word 2003 files not retreivable from Cruzer 8GB
I would suggest copy the file ot yoru desktop and open it from your desktop.
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
