Question about Lands Phones
Panasonic kx tga560az cordless base
My base set does not respond when i push a button. lloks like it has frozen. Have switched off and then on a few times but no luck....any suggestions please?
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
Posted on Jul 23, 2008
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
sodeep
  • 3267 Answers
SOURCE: english manual for Panasonic KX-TG1100CE cordless phone
You can downoad it from this link: http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1100ne_kxtg1102ne_kxtg1103ne.html or you can buy a copy from : http://www.cordless-phones.uk.com/cordless-phones/digital-cordless-phones/panasonic-kx-tg1100-phone
................................................sodeep
Posted on Jun 23, 2009
HelleP531
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
Posted on Feb 11, 2010
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
When I try to make a call with my Panasonic kx-td7895w cordless phone, it says in the display "PITS-PGM NO?" What does that mean??
That depends on what you have the phone connected to. There's a switch on the base that referrs to EMSS. It's a dual Panasonic SYSTEM phone or Single line cordless. The PITS-PGM NO? means you've pressed the PROGRAM button in the EMSS mode.
Carl
Dec 20, 2009 | Panasonic KX-TD7895W Cordless Phone
Panasonic kx-tg5839al cordless phone on base set #1 button only works intermittently. Is there an easy fix for this (out of warranty)
No, the keypad is worn out. The electronic need to be replaced. Could be more costly to have repaired.
Apr 29, 2009 | Lands Phones
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
KX-TD7895 problem
If you were using this unit and it was functioning, then most likely the handset has gotten damaged, and you would need to send the handset and base into repair (its not programming setting or a field servicable problem). If your testing this unit for the first time, the base may not "match" the handset. You can tell if they match by looking at the code on the little white sticker on the bottom of the base, and it must match the code on the sticker on the handset which is under the battery. So if they match, and they still will not communicate with eachother not much can be done until its put on a diagnostics and testing. You can google kx-td7895 repair to find a facility. Good luck
Apr 23, 2008 | Panasonic KX-TD7895 Cordless Phone
Line will be busy with static
you need to replace the phone with a new one .
Feb 26, 2018 | Panasonic KX-TG6702B Twin Cordless Phone
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
19 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
