Question about Tag Heuer Formula 1 CAH1111.BA0850 Watch
Tag Heuer Formula 1 CAH1111.BA0850 user manual download
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
Brian032472
  • 150 Answers
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Posted on Nov 06, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Posted on Oct 10, 2009
SOURCE: formula 1 battery replacement
I did it myself.Very easy use battery #394 buy at Walmart $5 made in Germany. I bought special tool to open and close the
watch on ebay
Posted on Nov 21, 2009
Does anybody know the correct part number or provide a link where I can purchase a Bezel ratchet spring for Tag Heuer WAC1113.BA0850 Formula 1?
Hi thank you for answers but it doesn't help me given I already have the bezel off. What I actually need is the actual size of the Spring? I know they are available to buy on eBay and watches.com.uk but to not even bother to respond to you inquiries for some reason?
Does anybody know the correct size of the "friction/ ratchet bezel spring" on a Tag Heuer WAC1113.ba0850 model 2004 - 2007 ?
May 11, 2016 | Tag Heuer Watches
Need manual for Tag Heuer CL111A-0
I have the user manual in PDF file. If you still need it so I can email it to you.
Feb 11, 2012 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
Cl111A-0 manual
I have it in PDF file
if you still need it let me know
Oct 08, 2011 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
How to setup the alarm to my tag formula1
I couldn't locate your model but if you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1113.BA0850 , you will find the details of a similar watche. In the menu at the side you will see "instruction manual".
Jun 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I cant seem to find my instruction booklet. where can i get some info on my CAC1111
Go to the Tag web site "www.tagheuer.com/the-collection/tag-heuer-formula-1"
Select "men"
Select your watch and on the right you will see a menu,
select user manual and download.
Jan 15, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I need a user manual for the Tag kirum Formula 1 watch
Go to the Tagheuer web site (www.tagheuer.com/)
Select "watches"
Select "Tag Heuer Formula 1"
Select "men"
Select "Tag heuer F1 chronometer"
On the right hand side of the screen you will a menu and the user manual is the last iten on the list.
Jan 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Early tag heuer professional 200m wrist watch
nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
Jan 25, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Tag Heuer Formula 1 CAH1111.BA0850 Watch Logo
422 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
