Question about Chevrolet Vehicle Parts & Accessories
The p/w ,pdl and p/mirrors dont operate on drivers side door panel 99 corvette what can the problem be?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Check fuses most cars with pwd/locs/pwr /mirros have seperate fuses for left and rright side also look inside engine for fuse box containing relays,might be needing if u find them swith right to left to dee if it workks all then if it does replace both relays for both sides!!!
Posted on Jun 19, 2014
How to replace driver's side mirror 1995 Roadmaster
You have to take the door panel off , I'll send this youtube link. It isn't the same car but there all pretty much the same ! How To Install Replace Broken Damaged Mirror 1992 99 Buick Lesabre
Dec 23, 2014 | Buick Roadmaster Cars & Trucks
Electrical problem with p/w p/l and mirrows 99 corvette
The most common issue is a broken wire or wires inside the plastic insulator of the wiring harness that runs through the rubber boot from the door to the body.
Feb 19, 2012 | Chevrolet Corvette Cars & Trucks
Describe how to replace 2002 driver side mirror
remove the left door panel screws by inside handle and remove the 2 big screws in the arm rest may have some covers on it then with the panel clip tool or screw driver you need to hit the inside top of the panel as you lift up with you hand dont break the panel. carefully remove the door panel clips to release the panel. remove the screws inside the door at the mirror unplug the connector have someone hold the mirror so you dont scratch the car. then pull it loose and reverse the prosess.
Dec 11, 2010 | 2002 Oldsmobile Bravada
I need to replace the passenger side mirror on my '99 Accord. It has power widows/locks. I have the replacement piece in full, but hesitate to begin removing the door panel w/o some knowledgeable advice....
you have to remove the door panel and upholestry as well as the side shield blocking the bolts to the mirror.
1.)remove door upholestry by unscrewing the screws,
  • under a hide cap by the door handle,
  • under the door opening lever
  • and some other places Look closely
  • remove the clips by prying the panel back.
  • remove electrical jacks connecting to the switches of the door
2.)remove the side shield blocking the bolts to the mirror
install new mirror.
Mar 04, 2010 | 1999 Honda Accord
Drivers side mirror fell off the whole assembly how do i fix it
On a 1997 blazer, how to remove drivers side mirror
under your handle to close the door is two 7mm bolt and behind your handle to open the door is a philips screw and that plate behind it comes off then CAREFULLY remove the door panel trust me you dont want to break the plastic then you will see your mirror bolts and electrical wiring
Oct 21, 2009 | 1998 Chevrolet Blazer
Does the wire for the passenger side view mirror connect within the door panel and does a new mirror assembly come with the wire
side window mirrors are operated by the driver therefore the wiring are on the driver side.
Aug 30, 2009 | 2005 Toyota Corolla
How do I replace the drivers side mirror assembly on my '99 4runner?
you have to remove the door panel and there will be 3 nuts that hold mirror on.
May 19, 2009 | 1999 Toyota 4Runner
Front door locks on a 99 passat
You have the wrong KEY if it won't turn any locks.
You can use the KEY fob from another Passat.
The one you have was most likey not the original
and the car was reprogrammed to except that FOB.
The Fuse panel Is inside the DRIVES side.
Open the Driver door. Look at the side of the DAShboard.
THat Giant "B" Shapped plastic cover pops off.
Check the fuses...IF any are broken,black or no good.
REplace them
Hope this helps
Sketchlab.com
MugShot Collection.
May 11, 2009 | 1999 Volkswagen Passat
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Apr 12, 2009 | 1999 Ford Explorer
How do you remove the door panel on a 1997 corvette?
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Jan 11, 2009 | 1997 Chevrolet Corvette
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
