Question about Sanyo PLC XU35 Multimedia Projector
Bluray into mu sanyo plc xu35
I just bought a blu-ray dvd player and a dvi cableĀ  and a hdmi to dvi video adapter by belkin i figured this would be the best way to get the best looking image but the screen only went black and the only option was 480p i got the bluray to work with an svideo cable and changing the aspect ratio to wide - and it looks pretty good but do you know a way i could connect into the hdmi input for better image quality?
tinamarie49
  • 34 Answers
SOURCE: Model number of Sanyo Pro XtraX
Yes it is.
Posted on Dec 05, 2007
Marrie
  • 563 Answers
SOURCE: pixelated screen on sanyo plvz2
Hi focushere
This could only be one of two things - either the cable that will need replacement or the Mainboard of the Projector.
Try using a different cable first , in other words a new DVI cable.
If this doesn't fix the problem ( which I'm sure is going to ) you will have to get the Mainboard repaired at a Service Provider.
Posted on May 19, 2008
  • 84 Answers
SOURCE: plc-xu35
are the other top controls working like power, menu,select etc??
remote problems can be caused by inproper code settings in the setting menu items.
try to switch to " code 1 "
Posted on Sep 25, 2008
  • 7 Answers
SOURCE: Have a Sanyo PLC-XU35. For some reason using it
Have you tried changing the refresh rate. It is located under "Control Panel, Display, Setting, Advanced, Monitor" I have had some success trying this.
Good Luck
Posted on Oct 19, 2009
  • 21 Answers
SOURCE: I would like to connect my Sanyo PLV-Z2 project to
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Posted on Mar 10, 2010
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Jan 08, 2014 | Hyundai Televison & Video
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I have a 51UWX20B TV. I want to get a Blu-Ray DVD
Yes there are a few options for you to make the link between your TV and the BluRay DVD player, first there are adapter cables made with HDMI plug on one end and DVI plug on the other end, remember that with this cable you will have to link the audio signal with another cable because DVI only passes video. Second if you cannot find the adapter cable in your area you also can use the component video(red,blue,green)instead of the other adapter cable,that is if your TV has component video ports, and again audio will have to be linked with another cable because component video only passes video signal. Good luck !
Nov 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Sanyo PLC XU35 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
