Question about IBM E74 Monitor
EHT 79A774 -503CG AND 79A774 504CG ARE SAME
I HAVE IBM E74 MONITOR.ITS EHT IS LICKEGE.SO I BUY A NEW EHT NO.79A774 504CG.IT IS RIGHT FOR THIS MONITOR
SOURCE: self-test
well screen might be bad does it work on anther comp ? if so yes its bad if it does work on other cheak video card drivers and card itself ok thx nick
Posted on Mar 13, 2008
avsantos
SOURCE: color problem
Hi, it is more likely from an open green and/or blue picture tube's electron gun transistor driver.
If you have an experience on electronics / or use of solder gun, you can just open your monitor and look for the electronic board at the back of the picture tube. Take a look in all transistor ( components with three legs) and solder / check if their legs are not fully soldered to the board. Note: just be careful on the high voltage diode / line ( the one with a thick (like the car distribution wire cable) single wire going to the tube). good luck
Posted on Dec 19, 2008
Techno-Geek
  • 38 Answers
SOURCE: monitor unlocking
OK .. Here is the solution.
Goto this link:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/visuals/e74e.pdf
Page 7, Second last line will solve your problem.
("Hold the OSD settings button for 10 seconds to unlock the controls')
Thanks and have a nice day. (please dont forget to rate this solution).
Regards,
Techno-Geek.
Posted on Apr 16, 2009
budmrtn
  • 11361 Answers
SOURCE: IBM E74 monitor running Windows XP: All white
All the pins at bothe end of the video cable are good and seated tighty? Does it do the same with another PC, need to verify to make sure it is not videocard problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 29, 2010
alpug
  • 1961 Answers
SOURCE: Please send me service and
schematic manual for monitors are not available.repairing a monitor dont need any schematics post the problem here will teach you how to do it. thank you!
Posted on Feb 17, 2011
Ibm e74 monitor is no but signals is showing one time only 2 second than Blak screen power led alos on, one time eht is on than is off
Hi.try use other monitor connect to your CPU. if it's running good problem of your monitor data cable CPU to monitor. you need to trace loose wiring or pin of cable to CPU maybe loose.
See attach picture.
Jun 18, 2011 | Computers & Internet
Greetings! We are using IBM E74 model CRT Monitor, The monitor was dead, No power, no display How can i rectify that? please give me the instruction
Jun 11, 2011 | IBM E74 17" CRT Monitor
Please send me service and Schematic manual for IBM monitor E74. Thanks million.
Feb 17, 2011 | IBM E74 Monitor
Ibm e74 17 crt monitor screen is black with the indicator light flashing green.
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....monitor LED just blinks & no display .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.... SOME TIMES ALONG WITH EHT....A TRANSISTOR ( BIG IN SIZE & FIXED NEAR EHT) ALSO GETS DEFFECTIVE...........SO IT SHOULD BE COMPULSORYLY CHECKED BEFORE REPLACING EHT
Jan 24, 2011 | IBM E74 17" CRT Monitor
No power for IBM monitor model 6332-4CE
Your monitor power section has been faulty. so pls repaired it from service center.
Mar 24, 2010 | IBM E74 17" CRT Monitor
The screen is blurry on the top, bottom and sides, but the middle is somewhat clear. how can i fix it? thank you for your time!
open the monitor a black EHT will found see the preset set it by screw driver on line see result on the screen the name on preset is FOCUS
Nov 13, 2009 | IBM E74 Monitor
Hi I have IBM Desktop computer with 17" E74 monitor. I am facing problem of to adjust the setting of display (brightness, contrast etc.)
Fn key bottom left key, works with other blue keys. Find other blue keys maybe arrow up arrow down or two with blue picture maybe looks like light bulb headlight the sun probably on the right side, press FN hold while hitting other key several times
Jun 08, 2009 | IBM E74 Monitor
Monitor unlocking
Goto this link:
Regards,
Techno-Geek.
Apr 16, 2009 | IBM E74 17" CRT Monitor
Automatic popping up of the monitor menu
i hav got fed up of this problem in my ibm e74 17'' crt monitor......isnt there any solution other thn replacing the transistors & diode coz its a very diffficult option......plzz help me if u can.....thanx
Jun 11, 2008 | IBM E74 17" CRT Monitor
IBM E74 Monitor Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
