Question about Hotpoint FFA80 Bottom Freezer Refrigerator
Hotpoint FFA97 freezer leaking water
Water running down the inside back wall and out of the door of the freezer.
  • 1462 Answers
SOURCE: Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Posted on Aug 29, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: fridge freezer not working Hotpoint RFA17
It is one of two things. Either your compressor went bad or the relay that connects to the compressor is bad. Those are the only two reason why it would not cool at all. You can try to unplug it and plug is back and and see what happens it might shock it back
Posted on Feb 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: leaking hotpoint 21.7 cu. ft. csx22bc
Your defrost drain outlet is frozen over.
Turn off the fridge.
Remove the bottom drawers.
Look in the back section just below the back freezer panel and you will see an ice dam.
This must be defrosted. Use a hair dryer.
Once all the ice is gone pour water into the drain to make sure it is clear.
Then pour a 1/4 cup of bleach in the drain.
Turn the fridge back on and you will be OK until it happens to stop up again.
Posted on Mar 01, 2009
tborn6
  • 700 Answers
SOURCE: the hole that drains water away at back of fridge is blocked
your going to have to take a wire and gently try to clear the drain line and then run water down it until its completely cleared out.
Posted on Mar 25, 2009
SOURCE: water not coming from spout,pressure in the line into door to spo
I have the exact problem with my side by side, water gets to the bottom of the door, and no further. Like Dan said, don't see how to open up the door.
J Bod @ j.bodwell@comcast.net
Posted on Jun 01, 2009
Model F44P21AT Water drips out bottom of freezer door.
see this link=> Leaking Refrigerators
Clean out the defrost condensate drain found inside the freezer back wall and a tube running down the back of your model. You will need to force hot (with turkey baster)water through the condensate drain to insure the water drains down the back and into a pan next to the compressor
APPLIANCE 911
May 28, 2016 | Refrigerators
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Ffa97 problems why is fridge compartment is freezing any food that is at the back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
I have a hotpoint refrigerator model CSX24XJ that was leaking water out the freezer door. I found that the drain was clogged and fixed this but I cannot find the drip tray. Does this model have a drip tray...
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Yes your model has 2 drip trays. 1 is below the evaporator inside the freezer and behind the back wall covering the evaporator. The other is below the refrigerator next to the compressor where the condenser fan heats the water and returns it back to the air inside your home. Thanks, Sea Breeze
Jun 28, 2009 | Hotpoint Refrigerators
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Hotpoint FFA80 Bottom Freezer Refrigerator Logo
157 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
