Question about Garden
I have a Victa Sabre 450 series 148cc B & S engine...9T702 Model 2129 B1 type 08012552 Code...have been thrown the task of mowing since Hubbie left me and have succeeded the past 4 times. But now it won't run. I have cleaned the spark plug and checked the guage (had oil on it) and looked at the carbi and air filter. If I put petrol into the carbi it catches and runs for a few seconds then dies. Even with the priming it isn't getting any fuel into the carbi. What can I do? Thanks in advance.
3 Suggested Answers
  • 41 Answers
SOURCE: stupid question I know but is it 4 strock or 2
If there is a place for motor oil on the engine, its a 4 stroke, and use 10w-30. If not, use a 40:1 mixture (gas to 2-stroke oil ratio). Not a stupid question... only stupid if you didn't ask, and did the wrong thing without asking first! Hope this helps!
Posted on Oct 20, 2011
  • 316 Answers
SOURCE: I have a Victa Sabre 450 series 148cc B & S engine...9T702 Model 2129 B1 type 08012552 Code...have been thrown the task of mowing since Hubbie left me and have succeeded the past 4 times. But now
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Posted on Feb 20, 2012
Testimonial: "A kind neighbour had a look and it was a blocked fuel line. He did exactly what you suggested and it's now running again. Thanks so very much for all your help! Gail"
Ihave a Briggs&Stratton 450 series 148cc push lawn mower it has seperate compartments for oil&petrol it ran out of oil 2day what type of oil do i need?
Hi SAE 30 in warmer temp ::::::: SAE 10W-30 in colder temperatures... also in temp below 5° C SAE 5W-30..... Cheers
Oct 25, 2016 | Garden
Where can I find a Briggs & Stratton 450 series 148cc magneto?
best place is from a B&S mower shop. Try e-bay as well as they are available on line. may be you know some one who has a mower that is not going that you can get the unit from it.
Jun 17, 2013 | Garden
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
I have a Victa Sabre 450 series 148cc B & S engine...9T702 Model 2129 B1 type 08012552 Code...have been thrown the task of mowing since Hubbie left me and have succeeded the past 4 times. But now it...
Feb 19, 2012 | Garden
Stupid question I know but is it 4 strock or 2 strock oil for a victa 450 148cc
Oct 20, 2011 | Briggs & Stratton Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
