Question about Measuring Tools & Sensors
Rocktrail weather station ian 58787
Ian 58787
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Tip
USING THE WEATHER BAND STATION 1. FOR WEATHER STATIONS, CLICK THE WEAIHER...
1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO “WB”.
2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
I'm looking for operating instructions for a Professional Wireless Weather Station with Outdoor Sensors WH5302
Go on e-Bay, look up weather stations, and send a note to tech support via e-mail to Raul. He seems to care about issues with the DR Tech weather station (I've had many, issues and weather stations!). Rick
Apr 30, 2014 | Measuring Tools & Sensors
Easy weather station not picking up the data from my weather station
This is the quirk with these "weather stations." They're battery operated. When the temperature gets down to a certain point, the voltage output from the battery drops below the minimum required to operate it.
You lose the signal from that station. Lithium batteries help...
Mar 09, 2014 | Measuring Tools & Sensors
Select a weather station
Davis is most reliable even with isolated incidences
Aug 30, 2012 | Davis Measuring Tools & Sensors
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
Software for Weather Station EC-WS115
reguire driver/software for ec-ws115 wireless weather
Apr 01, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
228 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
