Question about Panasonic SA-HE70 Receiver
S video input not putting out :)
Trying to use the s-video input to display my computer screen on my tv (to watch movies and such). I have an old tube tv and a panasonic sa-he75 receiver for my dvd and tape player. However, I plug in the s-video cable, reset my computer and tell it to mirror images from my monitor onto the tv and the computer recognizes it but nothing shows on the tv monitor?? i tried all display channels... any advise??
  • cysgodarth Nov 23, 2008
    I have exactly the same problem. Although to be fair I've tried hooking up my dvd player to the same svideo input and i'm getting the same results. Having had this unit for a number of years I'm not sure that the svideo inputs have ever even been utilized thus far. Any help is much appreciated!
  • Anonymous Mar 07, 2009
    same problem here
  • 905 Answers
To get the s-video to work you cannot have a component or rca video input while using the s-video for input to the tv
if it is still not working then you may have a problem internally and it will need testing to find the culprit
electech
Posted on Nov 26, 2008
I have an old Orion TV134R . The picture is so dark on it that I need night-vision goggles to watch it . How can I brighten it up? I don't have the original remote control. Thank you.
how about in the menu button you can not get an adjustment in brightness control. if the display in the screen is too dark either in any channel or even watching a movie from an input source like dvd player, then i may say that the picture tube need now replacement.
Aug 12, 2012 | Televison & Video
Sharp TV wont display computer screen
Looks like you have tried to connect two together, when either or both were in switched on condition. It is not advisable to connect any input, when the device is on. First, check for any changes in settings. Then, if these are ok, switch off TV manually, switch off power and just disconnect the TV from the mains outlet and leave it like that for 48 hours and retry.
Jul 30, 2012 | Proscan 32LB30QD 32 in. LCD TV
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
Jun 07, 2011 | Televison & Video
What channel do i go to for svideo cable??
The TV doesn't output the TV as such, UNLESS it has what is called a "Monitor" Output Sockets on it. Then you can connect up to, say another "Screen" or Take the Outgoing Video, & Sound, and "Record" it to a PC, via a Video INPUT via a TV/Video INPUT card. BUT you cannot play the TV on the laptop, FROM the TV. like you wish to do. If your laptop has a TV card INSIDE your laptop, then you could use that and display the OUTPUT from that TV cards' tuner, on the TV. But not the "other" way around. That SVHS is ONLY an INPUT out from your PC. You can put you system into either "Cloned"mode, IE: Whats displayed on laptop screen,is also displayed on the TV, Or, you can have as you seem to now, Extended Desktop. I hope this clears things up for you. Also when using that SVHS connection the Audio comes OUT on the Red & White AV sockets on the set. So you need that cable and another pair for the Audio..
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
How to connect vista laptop to tube tv
If your laptop has a s-video output you can get a s-video cable that goes from your laptop to your tv's AV input.
You then just have to activate the alternative display on your laptop to make it work if it doesn't detect it automatically. Hope this helps.
Cheers
Sep 30, 2009 | Televison & Video
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
Thimkpad t20 s-video not working
You don't go into display properties; you just tell your computer to output to the external monitor by pressing the Fn key and another key on your keyboard; sometimes its F4...it will have a picture of a screen on it...
Looking at a blurry picture of the keyboard, it looks like the key could be F7.
So, first connect your computer to the cable and to the TV. Set the TV on the input that you are inputting to. Press FN + F7 and it will route the display from your screen to the output. If you press Fn + F7 again, it may route the display to both the screen and the TV.
Thanks and please remember to give this a thumbs up rating.
Apr 26, 2009 | IBM ThinkPad T20 2647 Notebook
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
My new universal remote
Jo have you plugged in the Audio and Video cable in correctly. You need to check that the Video cable is in the corresponding input on the TV
Jun 08, 2008 | RCA Universal Remote Control
Movie Files will not display on the TV.
Its quite possible your laptop has lost its association with your TV as a "secondy monitor".
To check this, minimise everything and right click on the desktop and go to Properties. Then navigate to the settings tab. This will show you how many displays it considers itself to have.
Click on number 2 (if visable) and click on extend my windows desktop to this monitor.
You should now be able to go between screens
Apr 22, 2008 | Toshiba Satellite A105 Notebook
Panasonic SA-HE70 Receiver Logo
275 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
