Question about Sony Handycam DCR-DVD403 DVD Camcorder
Lens Cover will not open or close
When I turn on the camcorder an error message appears saying 'lens cover not fully open, turn off then on again'. Tried this and does not work. I can hear the motor trying to open the cover but nothing happens. When I try to open the blades with my fingers they move freely. Please help!
  • 7 more comments
  • abbasfazal Dec 19, 2007
    I have faced the same problem today with DCR-DVD403 (very low and careful use). I can see this issue reported in couple of sites by different consumer and couldn't locate any recall information.
    Pls. let me know if anybody has a solution.
    Regards,
    Abbas
  • GETAV8 Dec 22, 2007
    Not throwing up any sort of a code however the lense cover will not open. It makes a clicking sound as if it were opening but it does not move.
  • Anonymous May 12, 2008
    Having the same problem. The lense sounds like it's opening, but nothing happens.
  • Anonymous Jul 14, 2008
    My sony Handycam DCR-DVD403 DVD the lens cover is opening.
  • gsthomas707 Jul 18, 2008
  • huggableme Jul 27, 2008
    Have the same problem but the camera works if I force open the cover -- but my fingers are in all the videos and photos!!
  • samy9088 Nov 02, 2008
    i have the same problem , any solutions?
  • kinyanjui Nov 29, 2008
    I keep getting an error msg that the cover is not open. It appears to to be some what open. E:61:10 keeps flushing on the uper right hand corner. How do I fix it.
  • Sanjeev B Feb 10, 2009
    Lens cover will not open, though I can hear nise of motor running to open it.
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Posted on Sep 17, 2008
Looks like its a SONY factory defect on DCR-DVD403 DVD Camcorder Camcorders. I am having same issue.
Posted on Jan 17, 2011
I blew and blew but the lens cover wouldn't budge. So I used an air pump and blew high pressure air on it and still no go. Encouraged by you all's success I didn't give up. I used a small scribe (like a dentist's pick) and separated the gaps in between the lens cover lid and blew air inside each gap. Cover started partially opening. I repeated the process of blowing air in between the cover sections with air pump and yeppie... success at last. Working like a charm. And I am looking like a hero in front of the wife. Thanks ya'll.
Posted on May 01, 2010
I have this problem on my sony dvd403, try to blow some air using airblower for cleaning cameras and it works, maybe it was some dust that was catched between those covers.
Posted on Feb 16, 2010
I had the same problem with my Sony handycam DCR HC53E. Followed the advice on this forum, and used a balloon pump to blow air onto the lens - it released the mechanism & I used my fingers to open the lens cover completely. The air solution works!
Posted on Nov 14, 2009
Used air compressor to blow air into the lens cover, forcing it to open. Did this repeatedly. Lens cover began working & has worked since.
Posted on Sep 03, 2009
I read the solution posted here by a guest (opening the lens cover and blowing) and it worked...I also bought some lens cleaning tissues to clean up the moisture when I was done.....Thank you for helping me fix this!!!!!
Posted on Dec 26, 2008
Ive had the same problem, open the lens fully, blow a few times up each lens cover and jobs done!! its working!!
Only problem now is getting rid of the condensation in the lens through blowing to hard, its just a really bad foggy view now!
Posted on Oct 14, 2008
Open the lens cover with a tisssue and blow. i hope you get as lucky as I did.
Posted on Apr 13, 2008
I have read of someone forcing open the cover slightly then blowing onto the lense. Try a couple of times.
Posted on Mar 28, 2007
Posted on Jul 18, 2008
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
May 22, 2007 | Sony Handycam HDR-HC1E HDV Digital...
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Lens Cover
The micro motor broke in the dust cover that opens and closes the cover. If your camcorder is still operational then I would not worry too much. Only when you can not get pass the error messages to operate then you will need to get a new one from sony (~$50). If you are mecahnically sound to take apart small things otherwise, take it to a professional.
Aug 22, 2006 | Sony Handycam DCR-DVD203 DVD Camcorder
Sony Handycam DCR-DVD403 DVD Camcorder Logo
2,195 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
