Question about Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump
How do i change the sand in the hayward e1001542s
We need to change the sand in our pool filter and can not find our manaul. can you please help me thanks
  • Anonymous Apr 12, 2009
    how do i change the sand in my hayward pumpit would be nice if i could get some diagrams
We have changed the sand in our filter but now we cant get the back wash to work we have a davey tagelus 230 i need a diagraham to show how to put the muliti flow value on again
Posted on Oct 31, 2008
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
We need to change the sand in our filter ,it is a sw256t hayward ,but dont know how to remove other sand,does anyone know how?
Once you have the plumbing disconnected and valve removed,
Use a shop vac. Works well.
Once the sand is almost all removed, you can tip the tank over & rinse out with hose for the rest.
Jul 28, 2012 | Hayward Pro Series 18" Above Ground Pool...
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
HAYWARD SAND FILTER, PRO SERIES: sand is getting into the pool whan the filter is r...
Have you tried backwashing recently? If so, I would first check to make sure that your pool filter is on the "filter" setting and has not been changed. Next, i would evaluate your filter pressure to make sure that it is at an acceptable level. Finally, check your sand. If it is extremely dirty or has not been replaces in a long time, it might be time for fresh, more effective sand.
May 17, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the sand in a hayward model 711 sand filtration system. Are there any instructions for this out there?
While there is a model 711 Hayward Valve assembly, the actual filter is a different model number. You might be able to find your model here...
http://www.haywardnet.com/inground/products/filters/sand.cfm
Apr 08, 2010 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump Logo
1,273 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
