Question about Pioneer DEH-P47DH CD Player
No Sound I recently purchased this unit used and wired it to my Dodge Ram pickup. I took good care to make sure the wiring was correct. When I turned the truck's ignition on, I was able to power up the unit just fine, but I get no sound at all to my speakers. I have used a volt meter to check the connections from the wiring harness to the stereo and those are fine. There is no sound from a CD or from the tuner. Though the CD timer counts as it plays and the tuner shows the "Stereo" icon when I tune it. Every function on the unit seems to work properly, I just have no sound. I plugged my old factory stereo back in to test the speakers and they are fine. I'm at a loss where to go next. Afraid there is a problem with the internal amp or something. Any ideas?
Most ram trucks came with a infinity system. the amps are in the front doors, mounted to the 6x9 speakers. and they power the tweeters in the columms, and also rear speakers if you have them. I had to replace the entire system.
Posted on Aug 18, 2007
    Scholar:
  • 148 Answers
Does your Dodge have a factory amplifier? It definitely sounds like it. Try hooking up one of the speaker wires to an external sound amplifier or something like that and see if you get sound. If you don't, then you have a factory amp. You can also try touching the speaker wires with a 9volt battery and listening for a popping sound. If you don't want to test, contact www.crutchfield.com and ask if your truck has an external amplifier. They can help you find a bypass wiring harness so that you don't have to deal with it.
Posted on Oct 31, 2006
Where can I get a wiring diagram for a 1997 Dodge RAM 3500 diesel pickup?
1997 3500 Wiring Diagram - Dodge Diesel - Diesel Truck Resource Forums
www.dieseltruckresource.com/...dodge-ram.../1997-3500-wiring-diagra...
Jan 24, 2011 - Hey guys, I'm working on a 97 3500 that's had the bed removed and replaced with a flatbed. There is the biggest mess under that truck wiring wise and. ... 2007 Ram 3500 A/C compressor wont engage, need wiring diagram ...
Dodge Wiring Diagrams / Schematics - YouTube
? 1:13
https://www.youtube.com/watch?v=UI6_vhCHFYU
Nov 19, 2013 - Uploaded by Robert Nauert
Dodge Wiring Diagrams / Schematics ... Nitro, Power Wagon, Ram 1500, Ram 2500, Ram 3500, Ram 4500 ...
1997 Dodge Cummins - Full color wiring diagrams - 12 Valve ...
forum.mopar1973man.com/.../1638-1997-dodge-cummins-full-color-wi...
Jan 01, 2016 | Dodge Cars & Trucks
2003 ram 1500 pickup window will not work on passenger side but will work from drivers side. Have already replaced swith, but did not help
check for continuity across the switch wires. if nothing happens then you know you have a broken wire somewhere. make sure the ignition is to on. good luck
Jul 29, 2011 | 2004 Dodge Ram 3500 Truck
2001 dodge ram 1500 driver's rear blinker and brake light not working. Unplugged short harness at light, and no power going to plug. Any suggestions ???
trace all the wires back to the front of the truck and check for any broken wires. Also be sure that there is a good ground at the end of the wires behind the light
Nov 11, 2009 | 2008 Dodge Ram Pickup 1500
I have a napa trailer wiring kit for dodge pickup. can i use it on 2500 conversion van?
I don't see why not, but call NAPA and give them the part number off package to confirm.
Oct 25, 2009 | 1997 Dodge Ram 2500 Club Cab
Wiring diagram for 1998 dodge ram 2500 pickup,
I have the wiring diagrams you need. Send me your email address and I will send them to you.
Outdoorsman592003@yahoo.com
Aug 25, 2009 | 1998 Dodge Ram 2500 2WD
2003 dodge ram lights work on trailer but brake lights
try http://www.etrailer.com/faq-wiring.aspx. They have very good concise information that might help. Check wiring at each light. You can use the emergency flashers and a 12 volt test light to do this.
Make sure each light is grounded well. A loose ground will cause all sorts of problems. Hope this helps. Mike
Jul 04, 2009 | 2008 Dodge Ram Pickup 1500
1989 Dodge Ram D50, no spark. coil may be miswired.
Check the resistance on the coil. the (+) (-) side should be about 10 Ohms resistance and the part that goes out of the coil should be 1-2 ohms resistance. Get yourself an ohmmeter and check it. best way to check is to figure out what wire runs from the computer to the coil and follow the wiring all the way to the coil making sure theres no rips or shorts. If there isnt, then I would splice into the two wires and run two new wires over to the coil. If it still doesnt have spark then its a faulty computer and should be replaced. Good luck
Apr 20, 2009 | 1989 Dodge D150
1998 dodge 1500 4x4 pickup radio
remove the unit and check your wiring harness dodge uses a two part factory harness if the plug with all the speaker outputs came undone it would still turn on and function normal but you'd have no sound.
Aug 07, 2008 | 1998 Dodge Ram 1500 4WD
Pioneer DEH-P47DH CD Player Logo
246 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
