Question about Zodiac Nature 2 Cra30 Replacement Cartridge
Instructions on LM3-15 pool timer - Zodiac Nature 2 Cra30 Replacement Cartridge
Intermatic pool timer instructions
Timer is not identified. Do you have control center that controls heater, pump etc, or individual timer that controls pump?
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment.
Is this a new installation? Or did timer work before and stop working? What voltage are you working with?
Jun 24, 2013 | Intermatic Hardware & Accessories
How do I fix the auto on/off of my National Pool TB179 Timer? Are there user instructions?
Probably the small plastic switch inside timer broke, or switch no longer functions.
Otherwise, the TB17 timer appears to be 24-hour analog timer with plastic trippers, and knob that you rotate for on-off-auto.
These devices wear out after 8 years.
http://waterheatertimer.org/How-to-set-timers.html
Contact National pool:
http://www.nationalpoolsandspas.com/contactus.asp
Add a comment and attach photo of timer
Mar 05, 2013 | Hardware & Accessories
The supplier that fiited my swimmimng pools timers never gave me the booklet on how to set the time.
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Jan 02, 2013 | Hardware & Accessories
I have a question regarding the Intex Saltwater pump. If you cannot unlock the keyboard and set the salt timer will the plates on the ionization system still work or are they disabled unit the timer is set...
Must set the timer!!! It will not generate chlorine without setting the timer...
Try these instructions to unlock your timer and set the unit... If this helps, please rate the information.. Thanks and good luck!
Jul 23, 2011 | Intex Automatic Salt Water System for ...
My timer for my water feature looks like your Intermatic T101R3 timer. I do not have an instruction manual. Can you e-mail me some simple instructions for using this so I won't get charged an...
T101R3 is outdoor pool timer with fireman's switch.
Some are double-pole, some are single pole, some are 240V and others are 120V.
They each look like the other so eyeball identification is not enough information.
The model number should be inside door of timer.
http://www.poolandspacontrols.com/products/mechanical%20time%20switches/pool%20and%20spa%20time%20switches.aspx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
I have been unable to locate manual specific for these products, and I have looked.
I was looking yesterday for this instruction manual.
Some wiring diagrams appear on following page, but again it depends on your specific model
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The T101R series is designed to control pool pump and pool heater.
Fireman's switch automatically turns off pool heater 20 minutes before pool pump is scheduled to turn off.
So you set the trippers on dial, and then the fireman's switch does the rest automatically.
Add a comment with in-focus photo of inside of timer door and I can put together all the information and simplify instructions. Put your digital camera in 'macro' with the flower-symbol to take close-up photos. Photo has to be in focus so I can read information and see wiring schematic.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 20, 2011 | Hardware & Accessories
Zodiac clearwater LM3-15
Just found the instructions for this at this address
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
worked beautifully....good luck.
Sep 07, 2008 | Zodiac Nature 2 Cra30 Replacement...
Zodiac Nature 2 Cra30 Replacement Cartridge Logo
49 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
