Question about Loewe Televison & Video
Hi i have got a philips lc320w01 hd ready flatscreen, have fitted hdmi to dvi connector to change over to using a echostar hds-600rs,the sound is great on all channels and signal strength symbols good. but problem is picture freezing on all channels. any suggestions please.
HossBud
  • 6 Answers
SOURCE: Screen Size
When you are using the DVI connection on this unit it will automatically set the aspect ratio. There is no way to force it into stretching the picture as it will with other input sources. The only way to get to fullscreen would be to go into the setup menu on your cable box and set the "4:3 override" option to one that will meet your satisfaction. I'm having issues with this one skewing the picture to the left on DVI input. I'll crack it open one of these days to see if there are some adjustments that I can mess with on the inside. If there is anything further I figure out, I'll repost.
Posted on Jan 02, 2008
  • 1894 Answers
SOURCE: Illegal Signal DVI/RB 3
see this link...here is the user manual....
Posted on Mar 01, 2008
robotek
  • 1512 Answers
have you checked menus and HDMI paths on the tv
SOURCE: No sound on digital channels
Reset the unit . Switch off, pull the power plug of the wall receptacle and wait for about 1 min. Then plug it back in and problem will resolve. Check if you have the latest version of firmware
Posted on Jul 28, 2008
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
Problems connecting laptop to Philips TV
Is your laptop use fn F6/F7 to toggle between internal/external screen ? Try it
Jan 04, 2014 | Computers & Internet
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
I have just changed from sky+ to sky+hd. My TV is a Philips 26PF4310/10 with a DVI connector. I purchased a DVI-D to HDMI connector as instructed by Sky engineer and picturewise it works fine but...
You need to connect sound separately - DVI only supports video and not sound. You'll notice a 3.5mm audio in jack on the back of the Philips. You need to plug your sound output in there.
Jan 04, 2010 | Philips Televison & Video
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
How to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Oct 20, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips pf7320 model
if your using the hdmi input you need to make sure you have an hdmi capable input source on the other end if you are using an hdmi to dvi cable make sure you have alternate analog cables hooked up to something that will amplify them or go back to dvi to dvi and rca audio cables make sure the speakers are turned on in the menu
Dec 06, 2006 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
360 people viewed this question
Top Loewe Televison & Video Experts
Computer Repairing
Computer Repairing
Jerry Umali
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
