Question about LG Heating & Cooling
Kelvinator kse62hra aircon green power light flashing and wont turn on. Tried switching power off for 10 mins, cleaned filters etc but still nothing.
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
  • 17 Answers
SOURCE: TOYO TA-09CHS aircon problem
Okay, let do this;
Turn unit On and go out to condenser unit and see if the cooling fan motor is runing and strong.
I sure you cooling fan motor is not working.
Once the comoressor protector detected over heat it shut it seld down.
nguyen@ite.net
Posted on Jun 09, 2009
Krazytech
  • 725 Answers
SOURCE: What does E1 flashing on display mean?
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Posted on Sep 19, 2009
My Mitsubishi split aircon stops after a couple of minutes, and green operation light flashes. I have checked filters and timer, both OK. Will turning it off at the main switch board reset things?
your main board more so the pipe sensor connected to it, is defective. if the pipe senor can be changed it will work but in most cases the whole main-board will have to be changed as well.
Feb 07, 2015 | Mitsubishi Heating & Cooling
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
GOOD LUCK WITH THE REPAIR
Mar 10, 2010 | Samsung Heating & Cooling
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
Feb 11, 2009 | Samsung Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Dec 11, 2007 | Nintendo Wii Console
Heating & Cooling Logo
365 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
