Question about Toshiba Computers & Internet
Error 120000001 toshiba satellite 165-1762 error 120000001 size of harddisk was unacquirable
    Top Expert:
  • 1,575 Answers
Hi
You may need to scan the drive with an updated anti-virus.
Or probably repair your Operating System.
Hope it helps.Thanks.
Posted on Feb 19, 2012
4 Suggested Answers
pa1nkiller
  • 68 Answers
SOURCE: where can i find a cvd cover bezel for toshiba
call computer shops around town first then try buy and sell on google
Posted on Aug 21, 2009
micflynn
  • 8 Answers
SOURCE: How can remove BIOS password
These ppl have no idea how a laptop is built. There are no CMOS jumpars in a laptop, the only way to remove cmos password in a laptop is to use special software, hard to get and use because most laptops do not have floppy drives anymore, so the best way to do it is to dissassemble the laptop and desolder the battery for the cmos memory, one leg will do, wait 5 min then resolder it back. You may have figured out this is NOT for 98% of laptop owners, but a good repair shop and someone who really knows how to work on a laptop can do it in thier sleep.
Posted on Jan 13, 2010
  • 5 Answers
SOURCE: What is the utmost size of harddisk drive that a
The maximum drive capacity is dependant on the drive type. In this case, it takes a 2.5 inch PATA (a.k.a. IDE) hard drive.
There are different RPM speeds of 5400 & 7200, with the 7200 being a faster performing drive.
Most of these IDE drives have a maximum capacity of 320GB, which can be found cheapest at online stores.
One such drive is the Western Digital 2.5 inch Scorpio Blue 320GB
Here is a page on NewEgg.com that shows such drives.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=2.5+ide+hard+drive+internal
Posted on May 21, 2010
IDE #0 ERROR
Check your IDE cable is connected well.
Check your Harddisk jumper is placed vertical and not horizontal.
That might solve your problem.
Nov 16, 2012 | Toshiba Computers & Internet
Hi, I am using a toshiba satellite L645 which i got last December. I am now receiving the following error on boot... "Intel UNDI, PXE - 2.0 (build 083) Copyright (C) 1997-2000 Intel...
it seems that your harddisk is not dettect or may be your os has failed to boot.
turn on your laptop and press f2 to enter system setting
check on main field your hdd (ide configuration) is there any hdd installed? if there is no hdd instaled, it means that you need to replace your harddisk with a new one.
if there is any hdd now check your boot setting (boot priority), set your first boot in cd room and the second in hdd (in order to make easier instalation if the windows has broken) then save and exit.
May 13, 2011 | Toshiba Satellite C650DST2N02 Laptop
I can not find Harddisk in Toshiba Satellite A35-S1592 PC Notebook,Pls help me now I can not open data in Harddisk.Thank so much for read.
You can purchase an external hard disk casing to plug in your hard disk and extract the data on another PC.
Mar 08, 2011 | Toshiba Satellite A35-S1592 Notebook
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
I have a toshiba 305 and get the error message the instructions at 0x760f6770 referenced memory at 0x760f6770. the required data was not placed into memory because of an i/o error status 0f 0xc000000e.
It is memory related issue.
First check in back side of laptop and refix RAM memory .
Also you have remove bugs in harddisk for that boot your laptop with recovery disk or bootable winxp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y' then it fix error on harddisk.
For refix RAM you have open 1 small plate in back side of laptop it is for RAM module.
Aug 18, 2009 | Toshiba Satellite L305D-S5904 Laptop
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error...
check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Jun 17, 2009 | Toshiba Satellite A45-S150 Notebook
Need to remove hard drive in Toshiba Satellite M45-S169 and can't seem to figure out how to get to it?
ok when u power up the computer press "del' or F2 or F1 to enter in bios.
then if your go to ide configuration then u have to enable sata so your harddisk is removed means it is not detected.if u tell about internel harddisk .
Jan 09, 2009 | Toshiba Satellite M45-S165 Notebook
Satellite unacquireable.
never buy magellan there junk lol and the problem you are having is a broken flip out antenna on the back of your unit ..it is common with the older flip antennas just buy a external antenna from garmin and fixed .......if not send it back to garmin because its hardware is bad
Aug 23, 2008 | Garmin Nuvi 660 GPS Receiver
I need to replace my hard disk notebook with a bigger capacity hdd
Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
Feb 18, 2008 | Toshiba Satellite A10 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
