Question about Xerox Office Equipment & Supplies
Xerox 6115 all copies come out with two blank lines running the length of the copy, These lines are about 1/8 wide
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If this only happens when you use the Doc Feeder.. Clean the Slit_Glass, the little piece of glass next the large glass. Clean with a lint free cloth and alcohol.
If this happens when making copies from the main glass, it could be dirty mirrors/ lens, or internal problems.
if this happens when you print something from a PC, it is internal,
which could be a number of things?
something on the charge, the transfer, or your drum could be going and needing replacement, developer dumping, etc etc.
Posted on Oct 26, 2008
  • Mike S
    Mike S Oct 26, 2008
    oh wait it says BLANK lines not Black...
    void areas,
    if so probably the charge inside. or the drum is bad, and machine needs a PM..
Lines through my copies and faxes
Under the feeder there is a slim piece of glass maybe about 1/2" wide...it is probable that you have corrector fluid or dirt or some kind on this glass...us a soft cloth and some glass cleaner to clean the dirt off the glass.
Jun 16, 2010 | Canon Office Equipment & Supplies
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
WHEN YOU SEND A FAX IT LEAVES A LINE HALF INCH BLANK DOWN THE RIG
Does it also leave the line when you make a copy? Lift the lid and make a copy cover up. If it is there on the copy then most likely your scanner needs to be cleaned. If it isnt there when you copy, let me know we will go from there.
Dec 08, 2008 | Xerox WorkCentre M15i Laser Printer
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Apr 16, 2008 | Xerox WorkCentre XD120F Laser Printer
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
