Question about Kitchen Appliances - Others
Fryer at work is shooting flames out of the flute.
burzerko
  • 254 Answers
SOURCE: Pitco sg 18 s lpg
my friend it looks as if you have a leaking frypot. Do not use this fryer untill the frypot is replaced it is dangerous to use in this condition.
Posted on Nov 15, 2008
  • 8 Answers
SOURCE: flames in the exhaust of my american range deef fryer
Oil leaking into combustion area... needs ne pot. Might be under warranty...call factory with serial #
Posted on Feb 28, 2009
  • 11 Answers
SOURCE: our commercial pitco fryer shooting flames
check burners and chambers for soot build up. Check gas regulator valve
Posted on May 13, 2010
  • 77 Answers
SOURCE: flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Posted on Aug 16, 2010
kebah
  • 684 Answers
SOURCE: My Pitco fryer is shooting
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Posted on Aug 06, 2011
Why does my fryer have flames shooting out of the vent
no doubt grease has been spilled on it sometime and it's burning it off the elements .
Sep 15, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Yesterday my fryer started shooting flames out of the fryer. What is the problem?
Check for loose or broken gas line connectors, including the pilot line. Check for blockage in the flue in the back of the fryer. Things occasionally fall down there and people with the bad habit of banging the fry baskets on the top of the flue will eventually clog it up with food particles and carbonized grease. Check for a defective gas pressure regulator, which can cause excessive gas pressure getting to the burners. Check to see if the burners are properly in position and that the holes in the burner are not blocked by soot or grease.
You may be able to check these things by having one person very carefully open the main gas shutoff just enough to for a second person to try to light the fryer. Before attempting to light the fryer listen and smell for escaping gas. If the fryer lights, observe the fryer while the first person very gradually opens the valve further. This can be hazardous, and the person observing should stay well back and the person on the main gas valve should be ready to close the valve.
Personally, if the problem is not obvious, like a loose of broken gas line or a blocked flue, I would leave further testing to a qualified service provider.
Sep 21, 2014 | Kitchen Appliances - Others
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
Oct 26, 2011 | Pitco Frialator SG14 Deep Fryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
Flame not going into heat tubes
Tom
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
Loud POPPING noise and flames shooting out the bottom and light
It sounds like to high of voltage was applied or the unit was full of water.
Jan 29, 2009 | Toastess TDF-12 Deep Fryer
Pitco sg 18 s lpg
Sep 01, 2008 | Pitco Frialator SG18S Deep Fryer
Imperial IFS50
Hi, Probably the thermocouple. It will be right at the pilot light and hooks to the gas valve. The pilot heats it up to tell the gas valve that the pilot is working. If this is an electronic ignition, It will be the flame sensor still close to the pilot and will need cleaned or replaced. Hope this helps.
kstfas
Jan 10, 2008 | Imperial IFS50 Deep Fryer
Kitchen Appliances - Others Logo
93 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
