Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Can you run two monitors on Asus P5GC?
I just added an ASUS 219 Silent video card, and have tried to change the BIOS chip settings to try and recognize two monitors but it only recognizes one. Any information on the BIOS setting or is is somethin on Win XP that I need to change?
  • ASUS Master
  • 3,799 Answers
The Settings for 2 monitors on a graphics card are not in the BIOS, The settings you need are in the display card settings, (If the card is ATI based you need to look in "Catalyst".) The relevant settings are in there. You need to find the setup program for your card.
Posted on Feb 19, 2012
SOURCE: ASUS P5GC-MX/1333 - Audio driver
hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
Posted on Nov 09, 2008
ghouliass
  • 105 Answers
SOURCE: i need asus p5gc-mx mother board drivers
I hope you can find there:
http://www.clubic.com/telecharger-pilote-185769-0-asus-p5gc-mx-1333-bios-0410.html
and you can rate the fix.
thanks
Posted on Nov 21, 2008
SOURCE: realtek high definition audio can not start
download audio driver ASUS P5GC-MX/1333
Posted on Feb 18, 2009
  • 13433 Answers
SOURCE: Where can i download Asus P5GC MX/1333 Motherboard drivers?
Hey,
drivers and software for your motherboard p5gc mx 1333 are available on this asus page
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5GC-MX/1333
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 24, 2009
sodeep
  • 3267 Answers
SOURCE: i need Realtek sound driver for ASUS P5GC-MX
Visit this link:http://support.asus.com/download/download.aspx?SLanguage=en-us
or start from the begining from this link
Posted on Apr 01, 2009
Hello ,I just purchased an Asus desktop but I keep getting the message on my monitor,No Signal.Can someone help? Do I need to insert the video card first? No luck with configuring UEFI BIOS either.
Where is the monitor connected to the computer? Is it an analog or digital cable? Look on the monitor setup screen and see if changing the input signal will get you a picture. You're kidding about the video card, right? If the video card is in your hand and there is no place to connect the monitor cable....... duh.
Sep 26, 2015 | ASUS Essentio Computers & Internet
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
After a while the computer start sending blue signal
You could check to see if the northbridge or southbridge chips are overheating, but it sounds like one or more capacitors are bad even though they don't look defective(bulging or leaking). You did a good job narrowing it down. Probably best to just retire that motherboard.
Jun 01, 2012 | ASUS P5GC-MX/1333 Motherboard
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
ASUS P5GC-MX/1333 Windows 7 32-bit How do i enable the on-board vga as well as a pci-e graphics adapter simultaneously?
this would be donne first in bios and secondly under display properties/settings in windows.  this is assumming that the onboard graphix is capable of multi-monitor arrangements.
Dec 28, 2009 | ASUS P5GC-MX/1333 Motherboard
Integrated Visual (VGA).. Not sending signal
One never knows what settings the manufacture set the board to. So clear your bios. See the page 1-16 in your manual. Doing this should reset the bios to default settings. The onboard VGA graphics controller should send video to your monitor. If you still don't receive display the problem is with the bios or the graphics controller. Your board is no longer warranted. However you can buy an updated bios chip from Asus. Call 812-282-2787 M-F 8:00AM-5:00PM. Have your serial number ready. You'll find that number on a sticker over the LPT port. I already went to Asus online estore to see if they had a new bios but no such luck;
http://estore.asus.com/shop/category.asp?catid=137
Mike
Oct 15, 2009 | ASUS A8N-VM Motherboard
PCI-E recognition issue on intial start up ASUS P5GC-MX/1333
To solve this problem you have to do the following things in the series.
first remove all the extra cards and then connect to the onboard vga connector. then start the sys and go to bios settings. if you know the advanced adjustments then
correct them as follows. otherwise just select load optimized settings.
first go to the video card selection in advanced
and then set the setting to pci/pciinternal or pciint/pci ext
then set the pallette snooping to yes.
shutdown system
place graphics card and then donot change any setting. then you'll get the display.
i have the same motherboard and i also faced this once. it is not a problem it is just misconfiguration.
Apr 21, 2009 | ASUS P5GC-MX/1333 Motherboard
My mother board model is P5GC-MX,which not
Try reading the motherboard specification or user's manual/instruction manual if your new graphics card is in their product's whitelist.
Mar 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
BIOS update
the bios chip has numbers on it that identifies it it also has a name on it such as award contact the company from the name and replace the chip most asus mothert boards have an easy to remove dhip
Nov 22, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Change settings and hold them on vw 192 T asus monitor
Hi Paul,
Hope this solves your problem same I met before. There are a lot of queries it may involve here to streamline the problem. Well, first try to reset the monitor setting manually in OSD mode, then select different frequencies there and try each. To much with your PC video card frequency try changing the video adapter frequency properties on PC GUID or operating system video card panel. Try lower frequency first..
If the problem persist, like you've said it changes back to default setting when pressing the monitor setting buttons, there must be some problem in the circuit board of the monitor it cannot hold the frequency settings due to cold solder on control processor section and buttons. Other major defect is the CMOS chip to hold the settings and or bad caps.
Jan 30, 2008 | ASUS VW192S Monitor
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
