Acer Aspire RC500 PC Desktop
Problem for Acer Aspire RC500 PC Desktop
An Interesting Problem
By Trident on Aug 23, 2006
I have a Acer Aspire RC500.
what happens is the system will power up and work fine for a while, then all a sudden it will shutdown and not power up for the rest of the day. the top LEDs light up and the selection dial works, but the unit won't turn on. after leaving it off and unplugged for a day, i powered it up again and ran Microscope 2000 (a third party diagnostics program). i ran every single diagnostics from system board to RAM and Hard drive test which took all day and came up with nothing. when i rebooted the machine windows started then it shut down (when i say shut down i mean it just powers off)
Any help will be greatly appreciated.
If anymore information is needed please let me know
Cheers
Paul
Comments:
Aug 23, 2006
- Thanks i have already monitored the temp of the PC during the diagnostics it was a constant 36 degrees which is average from my knowledge. i even added a bit more compound to make sure there is no gaps between the CPU & heatsink fan. i am suspected the power supply or motherboard may have become defective. any thoughts?
Same Problem
Aug 13, 2008
-   My RC500 also started not powering up, or shutting down and sulking for several hours after a few minutes of operation. I replaced the electrolytic capacitors with bulging tops, and escaping brown goo in one case, in the power supply box with some second-hand capacitors from other (non-Acer) power supplies, and the problem seems to have stopped. The caps on the motherboard are all okay - it seems the power supply is the problem with the RC500.
Beejay5169
-   Beejay5169
Jun 27, 2008
-   how to monitoer cpu temperature ?-   fwk1941
Dec 14, 2007
-   i have the same problem it is the power supply that is faulty due to heat sinks being to small or so i have been told there is an alternative power supply u can buy yours should be fsp200-50gl(pf) the new one is py.20008.008 got this information from acer themselves but have not been able to get hold of one if anybody does let me know cheers email me with info @amebuildingservices@tiscali.co.uk many thanks-   Guest
Solution #1
posted on Aug 23, 2006
Somewhat Helpful)
habib_101
Rank: Wiz
Rating: 79%, 461 votes
You may want to check and see what the motherboard temperature is, as well. It's also quite possible that there's a short in the cables or the board which can also cause this issue. Any type of spark or short can cause the system to be non-bootable, if it doesn't fry it first.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
scifiguy
Rank: Guide
Rating: 83%, 47 votes
It sounds like the CPU is overheating. When the system boots up, can you hit the DEL, ESC, or F12 key to get it into BIOS mode? Often, there will be a setting in there to monitor the processor temperature.
If you can get it into that screen, leave the computer in that mode and keep checking the temp.
Make sure the machine itself has good air circulation and isn't in a hot spot in your house (for example, where sunlight hits the main box) If it continues to flounder, you'll probably need to upgrade the CPU fan or install a heat exchanger fan...
Was this helpful?
Yes
No
Solution #3
posted on Jan 25, 2008
Not Rated)
WillemVH
Rank: Apprentice
Rating: 0%, 0 votes
Hi, I met the same problem in the RC500 of a client about a month ago.
I monitored temperature and voltages.
It's definitly a powersupply failure, no heatproblem here.
The 5V drops in a day or two slowly below 4.75V and then the processor just stops erraticly.
Replace the PSunit by any other to test if you want, the case cannot be closed then but then you will be sure.
success, Willem
Was this helpful?
Yes
No
Solution #4
posted on Mar 07, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my girlfriends RC500. We sent it to acer a couple of times. But they didn't seem to find to problem so I decided to open the case en check some components. I think it might be the power supply. It might not have enough watt output so the system shuts down. Solution: Installing an old chieftec 380Watt PSU did the trick and it hasn't shut down since (going a good 6 months).
Popular Solutions for Acer Aspire RC500 PC Desktop
Questions and Unsolved Problems for Acer Aspire RC500 PC Desktop
Do you recommend Acer Aspire RC500 PC Desktop?
Answer
Answer
how can i insert square root sign and theta sign in microsoft visual c++?
Answer
Akai digital photo frame ADPF07X I cannot change the calendar and time from the manual. Can alter... (More)
Answer
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do... (More)
Answer
hi i cant get to start my pc
Answer
Hi, I was wondering if you've found ANY solution for your problem(as youcan imagine,i have the same... (More)
Describe your PC Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
