Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Door Tension Adjustment on Electrolux Dishwasher
I would like to increase the spring tension on the door of my Electrolux EDS5500 dishwasher. An installation manual references a door spring tension adjustment bracket, but it is not visible. Is there an accessable way to adjust it without uninstalling the whole unit?
  • Anonymous Mar 15, 2014
    how to adjust the seat belt tension spring in a toyota highlander
    President:
  • Indesit Master
  • 2,651 Answers
You should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Posted on Oct 26, 2008
Door lift spring came off how to put it back on
the spring will be at the lowest tension when the door is in the raised position
there should be an adjustment at one end where the spring is attached to adjust the ease to lift the door and hold it open so if thee is loosen that adjustment off and with the door held up ,refit the spring
Oct 22, 2015 | Hobart Used AM14 Pass Thru Commercial...
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
Fisher/p nemo dishwasher door
it is sometimes linked to the dishwasher not level or the spring tension on one side getting weak. Refer installation manual http://kitchen.manualsonline.com/mdownloads/c11d2c17-cb0a-489c-99bf-a61513fbf876.pdf to make sure the level is adjusted. May need to replace the door seal in case leak is too excessive.
Apr 27, 2013 | Fisher and Paykel Dishwashers
My dishwasher door will not stay up unless locked. I have installed new springs, to no avail
Might help with solution if you provide make and model number of dishwasher.
Sometimes the solution is a simple as ensuring the dishwasher is level so that the door shuts. The spring tension may need adjustment and usually there are a few screws at the top of dishwasher panel. Depends on make and model.
Jan 05, 2013 | Dishwashers
Dishwasher door won't latch
it is very likely the dishwasher is not levelled correctly or the springs in the door are too tight. Refer installation manual to check dishwasher levlelling and door spring is adjusted correctly. Please provide dishwasher make and model if you do not have the installation manual.
Aug 29, 2012 | Dishwashers
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
615 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
